car bogging under light throttle and throwing P0102 code
Old 09-02-2005, 03:07 PM
Odessastangslayer's Avatar
Unhappy car bogging under light throttle and throwing P0102 code
my 99 Z28 is throwing P0102 (mass airflow input voltage low) or something like that my car will run fine then it will bogg realy hard under light throttle,also surging at idle, also very rich when this happens,i push in the clutch and rev it, its fine after that i dont understand could the descreening of the mass airflow meter or long tube headers and no tune have something to do with this, this is makin me very angry i need help finding out whats wrong
Old 09-02-2005, 04:56 PM
Default whats wrong when this code pops P0102
my car is pulling this code P0102 trying to find out the reason for this it sais Mass Airflow sensor circut low frequencey does this mean i need a new mass airflow meter
Old 09-02-2005, 09:09 PM
"All Motor 9 Second club member"
TXCAMSS's Avatar
Sometimes a overly large cam will throw this code and requires you to change upper and lower MAP limits.
I would make sure that you have the MAF plugged in properly and that no wires are broken or that none of the plug pins got bent out of alignment. Also check the MAF resistor wires and make sure you didn't break one. Also make sure they are free of any dirt or oil. They are very sensitive. I clean mine with a Q-tip soaked in alcohol.
If that doesn't help, then find someone that you can swap MAFs with just as a test.
keep us posted.
Good luck!
Old 09-03-2005, 02:26 PM
3rdgenguy's Avatar
pretty much what he said the car doesnt sence how much air is moveing through the engine and can't add the right amount of fuel to the incomeing air hence the bog
Old 09-03-2005, 02:36 PM
3rdgenguy's Avatar
any drivability issues ?
Old 09-04-2005, 03:48 PM
yes a little most of the time its fine but occasionaly when under load at low RPM it starts to bogg and run rich when i push in the cluth and rev its fine after that does this sound like problems with the mass air flow meter its pullin P0102 (mass airflow input voltage low)
Old 09-04-2005, 04:03 PM
all the MAF meter wires and plugs are fine and in good shape,as are all pins inside the connector, just cleaned my maf meter with Q-tip and alcohol the small wires inside were dirty and noticed small improvement but not fixed by a long shot i dont currently have any friends with a car simular to mine so cant try the swap right now, Car has more than 100K miles on it do you think that it may just be time for a new MAF meter
Old 09-04-2005, 04:59 PM
also idle is surging bad it will almost die then jump to 1100 r's for a sec then be normal again this P0102 is the only code thats pullin up
Old 09-05-2005, 08:29 AM
LS1 Tech Administrator
Patrick G's Avatar
Check the 20a fuse marked "sensor" in the fusebox closest to the front of the car. If it's blown, you've found your problem.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 09-05-2005, 11:35 AM
hey man thanks alot the fuse is blown i would have never thought to look at that thanks so much you just saved me so much money and anger i love this web site now thanks for makin it so guys like me can fix their crap!
Old 09-05-2005, 11:49 AM
also could i just be in need of a tune from the long tubes cause it still dont seem like its running quite right that fuse was blown and i replaced it but its still not right could it be that the computor needs to be reset now to clear that code these problems started after i put the long tube headers and exaust
Old 09-05-2005, 01:34 PM
TAQuickness's Avatar
How longs it been since you replaced the fuse? Might just need to drive a few hundred miles so the trim's have time to re-learn
Old 09-05-2005, 08:23 PM
rainman's Avatar
I had the same problem, noticed an improvement when I replaced the fuse right away.
Old 09-05-2005, 09:27 PM
noticed an instant improvement reset computor, no more SES light i think everything is better now thanks for all of yalls help
Quick Reply: car bogging under light throttle and throwing P0102 code
