Help on SES and MAF please
Bought an 01 SS A4 and the SES light was on. Had it scanned and set off several codes. Anway, guy that scanned it says, after checking for air leak and not finding, its probably my MAF. I cleaned it and light still on. Any suggestions? I've also heard If I have to replace it, I'm thinking about going with the SLP MAF. It has 58000 miles and I it has SLP LM exhaust and I just did a TB bypass and cut the air box. I've also heard the SLP LM exhaust will affect the 02 sensors to throw a code, could this be a problem also? Any help will be greatly appreciated. Thanks
Ok, got the codes: P0102-MAF Circuit Signal Low, P0135-O2 Sensor Bank 1 Sensor 1, P0141-O2 Sensor Bank 1 Sensor 2, P0155-O2 Sensor Bank 2 Sensor 1, P0161-O2 Sensor Bank 2 Sensor 2. I also had the fuel pressure checked and it checked out fine at 50. Again, any help is greatly apreciated. Thanks!
