14° of spark rete @Wot
Hi every body …
My spark rate is 14° @Wot what is the mainly problem I have? As I know that it must be 24°-26°
Note: I have knock rate of 3 - 4@WOT but I don’t think that is the problem of (14°) correct me.
Thanks
Thanks
let me guess, you put in a huge cam, maybe heads, but you're on stock tune. so you moved your wot range like 0.20+g/cyl and car bogs badly, runs better at 3/4s throttle than wot, right?
you need to adjust your spark tables big time, watch which cell range you hit when you go WOT, and adjust it to your prefered values. how right that's gonna be is another story...
Guys you are extremely right for having cam with stock tune, but my cam not that big it is Comp 54-412-11
Here is my mode list which may help you to diagnose my problem
98 CAMARO A4 :
Comp Cam 54-412-11 / LS1 XR265HR-14
LT, OFF ROAD Y-PIPE, CUT OUT, LID, NGK TR6IX GAP 0.48 IN, Taylor Plug Wire, B&M Shift Kit, 3.73 Gear Ratio, Hypertech Power Programmer used far FAN mode and gear ration only. 97 octane fuel
98 CAMARO A4 :
