stoich a/f ratio
Old 09-24-2005, 03:02 PM
Recon12thman's Avatar
Default stoich a/f ratio
whats a good stoich a/f ratio for a n/a with oversized injectors headers and intake and exhaust
Old 09-24-2005, 03:30 PM
slow's Avatar
unless you change the fuel, you do not want to chance stoich ratio.
On gasoline, it is near 14.6x
Ryan
Old 09-24-2005, 03:35 PM
ok thanks what about the maf tables im usin hp tuners
Old 09-24-2005, 03:37 PM
slow's Avatar
You want to first determine what your commanded air fuel ratio you want to run, then set that into the tables that effect the commanded air fuel, the open loop, and the PE tables. Then you want to adjsut the airflow characteristics to get the fueling correct, depending on your setup, beliefs, or tuning style, this will be altering the VE tables and/or the maf transfer function.
Ryan
Old 09-24-2005, 03:46 PM
ok thats where ii get lost i enriched the system through the pe table and some people say timing is a good thing to do here as well so what shouldi do
ive also already adjusted the ifr table for my 42 lb injectors is there anythin else i should do
Old 09-24-2005, 05:09 PM
slow's Avatar
After setting the ifr tables, you will want to dial in your VE and/or Maf table to get the part throttle fueling correct by the fuel trims, then you will want to get the wot fueling correct, but need a wideband for that.
After airflow it correct, which should result in correct fueling as well, then you can tackle timing.
Without proper airflow, your timing will be wrong.
Ryan
Old 09-24-2005, 05:49 PM
ok whats a good number to start out when modifing the ve and the maf
Old 09-24-2005, 07:00 PM
slow's Avatar
you need to get data from the vehicle, you want to get your fuel trims as close to 0 as possible. Some this might only take a small change, others might be a huge change.
Ryan
Old 09-24-2005, 08:49 PM
ok what method did you use the ltft + stft or just the stft stand alone method and how long did it take you to get it all smoothed out
Old 09-24-2005, 08:59 PM
slow's Avatar
I always turn off the longterms, and then tune from there.
Time really depends on your motor combination. The current tune in my car consists of 20 minutes of tuning on a mustang dyno to get the upper maf dialed in, and about 1 hour of street driving for the VE table.
Ryan
Old 09-24-2005, 11:32 PM
ok so either way i do it it should come out goodright
