Mult Misfires
Mult Misfires
Pass Side only. Im not relly sure what the deal is I think the car may have been turned over or started to with the Pass side coil not plugged in all the way. Now when its plugged into HPTuners and reads coads Im getting Mult Missfires and ignition codes just on the pass side. The codes were cleared and when re-start it struggles to start then almost dies then after about 30 seconds or so it will idle at 800 (as it should with the tune)
When I go for a little around the block drive it stumbles a little when accel then push the clutch and hold it in and it falls to 400 then back up. What would happen to the coil if it was turned over and not all the way plugged in?
Btw: I have checked the plugs and the wires and no plug damage and wires seem to be ok as well.
Help I just want the car to run!
Thanks in advanced
Thanks in advanced
