friction torque vs oil temp
Old 09-27-2005, 09:45 PM
P Mack's Avatar
Default friction torque vs oil temp
I saw this table in hptuners and it seems like it could be useful but I didn't know the pcm read oil temp. Is there an oil temp sensor that I don't know about or does it go by coolant temp?
Old 09-27-2005, 10:01 PM
slow's Avatar
it could be infered oil temp, not sure if there is a real temp sensor to my knowledge. I know most ford diesel's have the sensor though.
These tables are typically a value entered by data that effect the torque table, used for calculatiing transmission shifting and other torque based changes.
Ryah
Old 09-27-2005, 10:06 PM
P Mack's Avatar
Well in this case it is calculating the torque and therefore the airflow it needs to simply idle. It may not need changing for idling problems but I thought it could be a factor in hot start vs cold start problems. Maybe it uses a combination of ECT, IAT and engine run time to figure out oil temp.
