Which wideband for HPTuners ?
Old 10-05-2005, 08:33 AM
Bad30th's Avatar
Default Which wideband for HPTuners ?
Hi everyone,
What is everyone using for a wideband to interface with HPTuners ? Which one is preferred and why ? Some details would be nice (accuracy, ease of install, failures, etc) ? I've heard the Dynojet one is good.
Is there a writeup somewhere on how to connect the sensor wiring to the pigtail ? (Couldn't find one with search).
Thanks !
Rob (Bad30th)
Old 10-05-2005, 08:36 AM
LS1TECH Sponsor
foff667's Avatar
ive been using my lm1 for over 6 months now...ease of install, price(at the time) and it was known to work well with hpt.
Old 10-05-2005, 08:41 AM
12secSS's Avatar
Hey Rob! I have used the LM-1 and now use the DynoJet. The LM-1 is easier to "install" and transfer from one vehicle to another. I was using a barrowed LM-1 from a friend, but I decided to purchase the DynoJet as per Ken's recommendation. I don't know if the barrowed LM-1 had a bad sensor or what, but my DynoJet is more accurate than the LM-1, plus it came with an extrenal gauge so I could easily monitor AFR as I drive/race. The LM-1 unit is a good piece don't get me wrong, I am just a very happy customer with the DynoJet.
Old 10-05-2005, 08:45 AM
LS1TECH Sponsor
foff667's Avatar
how did you determine the lm1 to be less accurate then the dynojet?
Old 10-05-2005, 08:49 AM
12secSS's Avatar
It was reading a couple points different then Ken's and the Dyno Pack's wideband readings. Something like .5 AFR. Ken's DynoJet wideband and the Dyna Pack wideband were very close to each other. This was done on the same day within minutes of each other ... as I said, it could have been the sensor itself was bad. I don't know, it looked good to me.
Old 10-05-2005, 02:50 PM
Bad30th's Avatar
TTT let's hear some feedback on other brands.
Rob (Bad30th)
Old 10-06-2005, 11:42 AM
LS1TECH Sponsor
DynotuneN2O's Avatar
We have a special right now on the LC-1 and LM-1, call us and we can hook you up!
WWW.DynoTuneNitrous.com 1-978-562-6040
Cheers
Dan
Old 10-06-2005, 02:22 PM
Blacker's Avatar
I have been using my LC-1 and it working great. Simple to install and use with HP Tuners.
Old 10-06-2005, 02:28 PM
soundengineer's Avatar
LC1 has worked great for me..
tuned a buddys car and he has the best ET at the track he has ever had right after my tune was done
horist's Avatar
the LM1 and LC1 are no doubt the best "bang for the buck"
I use an LM-1 and love it... I just hooked it up temporarily to a buddies car a week ago to tune his car....
the LC-1 is great if it's not going to be used in multiple vehicles... LM-1 is great for multi-vehicle
Old 10-06-2005, 02:39 PM
the LC1 is no problem for multi vehicle...
I almost always tune in open loop with LTFT's disabled(since I am using a wideband)
and I just pull out one of the front O2's and put it in its place....
being in open loop it doesnt care if one of the o2's isnt hooked up
I made a little box and attatched power and ground.. run grond over to the fuse box in the door panel...run ground to the seat floor bolt....start tuning
just be sure to hit one of the 25 amp spots near the lower right corner....
