what are the differences between 2001 and 2002 OS?? V8 F-Body
In a V8 F-body...
was there anything different in the OS...
meaning did they add anything or change anything other than the data in he tables??
like my example fo a change would be from 2000-2001 the removed the secondary VE, they added some tables in the complex cylinder charge area...
are there any benefits to updating from a 2001 OS to a 2002 OS (and obviously plugging back in your 2001 data in all the fields and tables)
just curious cause I'm already upgrading cars fro 2000 OS to 2001 OS... and just wanted to know if there ould be any benefits to upgrade to a 2001 OS
I did the OS compare...I have HP Tuners 2.0..I am a beta tester...
heres the list of differences..
Code:
Main File : 2001 M6 V8 F-Body.bin Compare File: 2002 M6 V8 F-Body.bin Main File Parameters : 496 Compare File Parameters: 494 Parameters Compared: 488 Differences : 4 Similarities: 484 Engine Idle Idle Airflow Throttle Follower Throttle Follower Delay Time vs. Speed (In Gear) 10 of 18 cells Engine Diagnostics General MAF Sensor Maximum Delta Airflow - P0101 Error 11 of 11 cells MAP Sensor P0106 Error MAP Calculated Max 38 of 77 cells P0106 Error MAP Calculated Min 64 of 77 cells
