my going super rich on decel issue - new clue found
I have been unable for months and months to figure out why the car goes 10.1 a/f under decel and will stay there until I touch the gas. Happens no matter what, with maf, without maf, with turbo, without turbo.....
well I noticed yesterday on a drive it goes wacky rich as soon as I hit 21" of vacum. 20 or less, car maintains it's 14.7 a/f. Let off the gas a bit more and hit 21" a/f drops like a rock. slighty touch gas to get it to 20" or less, A/F climbs right back up.
Does this light any lightbulbs for anyone for an area I should be looking into to solve this problem???
I would have to log again to find out. have not been logging injector duty cycles.
lets say they were not .5 or lower then what? IE where are you heading with that question.
thanks!
thanks!
I would look at a couple of things if it were me:
If/when DFCO activates.
TPS values ( PCM getting fooled? )
If you have DFCO turned off, what does the VE look like at those values (rpm, low load)
dfco settings - when stock it will go pig rich then go ridiculously lean as in over 20:1 so for now dfco is off
i have tried plaing with ve for that target area and have had the values so low it's ridiculous (in the teens) no effect.
i dont think it's tps since it will be fine until it hits that 21" of vacum. my eboost will output kpa so I think I am going to switch to that mode and see what that value is and scour tables for anything that jives.
well with dfco on it going leaner than 20:1 is not going work well, the car hates it. I don't believe it's supposed to go that lean with DFCO is it? I could investigate if there is a way to minimize dfco, that might work. what bothers me though is I feel I am trying to tune around another issue that I can't track down. I have the same injectors in my buddy's 98 TA that I tune and no such issue exists.
smoking - it does this with both lucas 42's and my current motron 60's, so it's not directly related to the injector.
please read above.
also does it with 42's and I have these same injectors in another 98 and it does NOT have the issue.
thanks though, all input is appreciated.
Allrighty I have nothing to lose to log and see but they work fine on another car and if it was a widespread issue I think we would see numerous posts about this.
In any case I will log and let ya know.
1 Post
I am seeing the exact same problem with two of our customers cars. Both cars have the exact same 42# injectors, same turbo setups, nearly identical to each other - one does what you describe, one doesn't! If I figure it out, I'll let you know.
you need to log injector pulse width. What injectors do you have? You might need to lower minimum injector pulsewidth, default injector pulsewidth ect if you are running large injectors
I'd say the motron 60's are to large for stock pulsewidth settings. Log pulsewidth and see what they are reading during decel when afr goes pig rich.
I did, i'll still bet a beer on it
Give the man a prize. Dropped the values down to 1.003 and it fixed it!
Now I just have to go fix the low end of the VE table I screwed up so bad trying to overcompensate
Thanks for the tip SmokingWS6! I am glad I wasn't too stubborn to not try your suggestion.
i have 42# injectors and no matter how lean the ve goes with or without dfco on below like 30 kpa it goes to negative 11 or so, no matter waht kinda fueling i have in the ve. but i havent checked out what it woudl read on WB yet
so you are saying to go lower min pulse width?
I gotta try that too, same thing is happening with my 98. Goes super rich on decel, especially on the highway. Yesterday when logging my WBO2 was reading 9.1s
So which screen would I go to? Just slap in 1.003 and that should do it?
J
