Are you guys adjusting the whole VE table?
On my dad's heads/cam car and my friends cammed car I noticed that the VE table was only adjusted from 400-1200 rpm. Is this right? Or are yall adjusting the whole VE table?
Brian
Brian
adjusting the idle rpm range only helps to speed up the process (tuning ve is a feedback loop, it will converge on a result eventually).
just tune your ve, you'll have to do it a bunch of times anyway. once you've done it a bunch of times, and you're tuning just idle, then doing the 'first 3 columns reduction' is a good startup eyeball technique, but that's all.
