P0300 Misfire Code...Amongst Others
Old 10-16-2005, 04:28 PM
rd_ls1_z's Avatar
Default P0300 Misfire Code...Amongst Others
I posted a little while back about a misfire issue I was having. The initial code was the P0300 random misfire. This would happen in the morning, or with high humidity. The engine would misfire, and when I would stop, the idle would drop to around 500 and surge back to normal, 800. Like everyone else, I thought it was the plugs. However, as time went by, the PCM threw a lean fuel mixture code, so I had to take it to the dealer. They found that my injectors for cylinders 2 and 6 were clogged, even though I ran injector cleaner through the car. Bad gas from the hurricanes? The injectors were cleaned, and I haven't had any problems since. Just thought I let you guys and girls know if you were having the same problems.
Old 10-17-2005, 05:09 PM
robertbartsch's Avatar
Yeh, I have had bad gas issues with both my cars. The cars are filled at a different gas station.
Consequently. getting ripped off from the high gas prices and poor quality SUKS.
Old 10-18-2005, 05:34 AM
Assassin's Avatar
so how did you end up cleaning them out?
Old 10-19-2005, 08:14 PM
rd_ls1_z's Avatar
Unfortunately I had to have the dealer clean them, don't have the tools... They took them out and cleared them somehow...not sure.
Old 10-21-2005, 08:15 PM
half-n-half's Avatar
hmm....i wonder if this is my problem? i have the same symptoms....
