Since a C5 doesn't have a true IAC ......
Hey Phil, what do you mean by using the ETC Area Scaler to make the lines overlap. Better yet, what did you end up putting in that value for your 90mm TB? Im still highly confused on the whole ETC and tuning.
Dixit
Dixit
Originally Posted by Dixit
So you basically want to try to get the desired as close to actual airflow as possible by playing with the scaler? What value did you use for your 90mm TB?
B4349 = .0320
Dixit- Use value HumpinSS gave. Set the IAC park table to "Stock" values. Recalc your RAF table as the values will be less.
As the ETC scalar value increases the Desired idle airflow (g/sec) decreases - i.e. the "steps" of the throttle blade increase in size resulting in more actual airflow. More actual airflow results in a need for fewer steps (less TPS%) at idle. Fewer steps = Less Desired Idle Air. Hope this helps some.
FWIW.
FWIW.
Will that value still be the correct one when I install a ported 90mm TB?
Bink, excuse my ignorance, but Im slightly lost now. Isnt Desired Airflow what the PCM is commanding to get a good idle? Isnt that always going to remain the same no matter what value I put in there, or is there something Im missing.
I definetely understand the whole part of the fact that im going from the stock 78mm to 90mm TB means that the TB has to open up less than before because the same the amount of steps are still the same however because of the larger opening the same step will provide more air.
The part I dont understand is what Phil was talking about scanning and figuring out where you sit and adjust the scaler accordingly. What am I scanning to see how the scaler is correct or off and how am I doing this?
Thanks
Dixit
Thanks
Dixit
.0320 is for a 90 mm tb. I don't know if a ported 90 mm tb will change this. This should not be used for a 78 mm tb.
The Scalar value is the conversion constant. Basically it's defining the size of a single unit of blade rotation ( think of the "steps" of the IAC vale on an Fbod).
As you increase the value above .0255 (stock) the "desired airflow" values are less because they are scaled by the conversion constant. This is why your RAF values will also be less. Make sense??
Here's the info you need -> http://www.efilive.com/forum/viewtopic.php?t=1169
Scan DESIAC and/or MAF and/or Dynamic Airflow. You should be able to get the MAF values to be nearly equal DESIAC. Dynamic Airflow will line up/coincide with DESIAC but (with a 90 mm tb) won't be equal. If the Eff Area Scalar is too great the LTIT and STIT will be erratic and unstable - I guess system is out of range due to the larger steps/% of the blade.
