hesitation in every gear 1100-1600rpms?
Old 11-04-2005, 04:11 PM
Red99TA's Avatar
Default hesitation in every gear 1100-1600rpms?
I'm running in SD and am in the process of tuning my VE table. Whether hot or cold whatever gear I'm in I get a bad hesitation from 1100 rpms up to about 1500 rpms. I don't notice it at light throttle say 10% TPS but up around 25% and above and it hesitates bad and I'll see some knock every now and then (around 2 - 3 degrees max). I know it's not going into PE based on my TPS settings. I've tried playing with VE columns 800-1600 (adding and subtracting fuel) and I've tried adding/subtracting spark and neither made any difference. I also noticed that when it's doing this the O2's go to 25 - 50 mV and stay there (flatlined). I'm not sure why the O2's do this or if this has anything to do w/ the hesitation. Please help.
TIA,
Geoff
Old 11-04-2005, 10:40 PM
technical's Avatar
Not knowing what a WB reading looked like, I'd have to guess you should pull a degree or two worth of timing and add more fuel. I know you have been adding, but I suspect you should add at least 1.5x the max amount you have previously tried. The situation "sounds" like a lean condition. If you had mentioned a bucking I would have went the other way.
Old 11-05-2005, 09:07 AM
Red99TA's Avatar
I'll give it a shot. The most I was changing before was + or - 20%.
Old 11-05-2005, 05:39 PM
Red99TA's Avatar
Just added 30% fuel in 1200-1600 columns with no effect. I can make the car do this in 4th or 5th gear starting around 1200 rpms and then opening the throttle about 50%. I don't understand why the O2's go to almost 0 mV and stay there while the hesitation is happening. It seems like during normal driving the O2's oscillate no problem and at WOT they shoot up to where they should be (around 920 mv). Any ideas?
Old 11-05-2005, 09:49 PM
technical's Avatar
Where do you have PE set to enable? I can't remember off the top of my head where default is....
Old 11-06-2005, 12:24 AM
Red99TA's Avatar
Enabled above a MAP of 15 with at least 64% throttle and this crap is happening less than 64%
Old 11-06-2005, 12:49 AM
technical's Avatar
Did this start right after the TB install?
Old 11-06-2005, 01:01 AM
Red99TA's Avatar
No, I just downloaded some new tables from another user who got me up and running in SD...my previous mail-order tune was all jacked up to the point where it hesitated like crazy in open loop while in SD in every gear at any rpm. Now it runs fine except for this hesitation at low rpms.
Old 11-06-2005, 10:53 AM
technical's Avatar
Post up some logs and the VE table if possible. I was starting to think you had an air leak that was causing the hesitation while transitioning into load, but it may just be the calibrations. Double check for air leaks just to make sure we're not chasing a ghost.
Old 11-06-2005, 01:45 PM
LS1 Tech Administrator
Patrick G's Avatar
Often, bucking and surging has to do with the IAC fighting against you. After you get your timing and VE tables perfect, then get your base running airflow nailed so your Desired Airflow and Dynamic Airflow match at all temps (AC on and off). To do this, you'll need to mess with your IAC Effective Area table.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
