Need help with SD tune..
Old 11-08-2005, 03:13 PM
5.3litre's Avatar
Default Need help with SD tune..
well i have tried everything to eliminate low rpm bucking caused by my cam but i cant get rid of it..i had a guy suggest i try SD and see if that will help at all..my question is will it throw my current tune all out of whack? cause right now i got my idle, afr, and everything else perfect except for the dreaded bucking..will it cause my idle and WOT AFR to change at all if i go to SD?..and also do u think SD can help me reduce the damn bucking? thanks!
Old 11-08-2005, 06:04 PM
5.3litre's Avatar
ttt anyone?
Old 11-08-2005, 07:02 PM
soundengineer's Avatar
Ok..
so you want to try SD...
first thing we need to know is how did you get your current tune???
was it a dyno shop tune?? cause if yes...then you might not really have a "tune"
IF you have never tuned your VE then there its going to be funky till you get it in line
ways to help the low RPM bucking.
try adding a few degees of spark down low....log it to see what cells it bucking at and increase timng a little...
lean out the fueling....check out the trims and use a wideband...get the fuel a hair on the lean side(this usualy helps immensly)
and next time..wait more than 3 hours to bump after your first post....
not everybody can sit on their computer all day to answer questions....
Old 11-08-2005, 07:17 PM
ninobrn99's Avatar
if i knew the answer, i could got nothing better to do here at work
Old 11-08-2005, 08:00 PM
5.3litre's Avatar
Originally Posted by soundengineer
Ok..
i have already tried everything u said to try..and yes i dyno shop did tune it, and they did a very good job..the ve table was tuned by them and its great except for the bucking issue..i just need to know if i switch to speed density if i have to tune the pe table and the ve table all over again and change all the idle stuff..thanks for the help..oh btw the i can bump my thread up anytime i want..i didnt know the the letters "ttt" would offend anybody..sorry..
Old 11-08-2005, 08:48 PM
muncie21's Avatar
I'm not an expert, but I think the PE table is only used in open loop mode, i.e. WOT, or close.
