What High Octane Timing Table do you use?
I'm just curious as to what timing tables you guys use, stock, modified stock or custom.
I tried to do a poll but it won't let me. What do you use:
- 1998 Stock Timing Table
- 1999 - 2000 Stock Timing Table
- 2001 - 2002 Stock Timing Table
- 2001 - 2002 Stock Timing Table - Modified
- 2001 - 2004 Stock LS6 Timing Table
- 2001 - 2004 Stock LS6 Timing Table - Modified
- Custom Dyno Tuned Timing Table on a loading Dyno
Bill
Bill
I used my stock 98 table and spliced in a lot of the highest timing parts for low rpm and smoothed it out, and smoothed out the entire WOT to 28 degrees of timing. Ran beautiful, no KR (after I fixed the knock sensors). With the factory settings for the knock sensors the PCM would pull timing at WOT even if it was at 16 or less degrees (even after a top-engine cleaning, fuel system cleaner, new plugs, etc, etc, etc).
