timing
timing
to much timing can cause ping or knock, can to little timing do this to.
my z is kinda riding 21 t0 26 degress with 1-2 smacks of kr not shure
were to pull or add.
so you were doing a WOT run, at 4678 RPMs you were at 21.5* spark @ 199 ect
@ 4748 is where your knock came in and pulled 4* of spark right?
do u have a cam?? im assuming its an auto cause of the gears....right?
stock 2002 z28 a/4, i pulled -2 degrees across the board and a little bit of idling and
intake over 85degrees makes it pings again. i dont want to fool with this to much
and burn the thing down.i wish i new witch way to go with this/ some
people say add some say pull .
i should of said i added 2 meaning towards o right bottom was 19 and top of table was at 41 ..... -2 to 17 and 39 across. adding means towards o right, thanks for my stupidity.
i know when my car was tuned, they desensitized the knock sensors a bit to make sure it was actual knock, not something else. try that out. about 3-4 degress since thats what its pulling. If this isnt the way to go about it, then im sure someone will correct me
i thanks youll alot man , i must be stoned or something. itsweird because every thing
seems to be right, but soon as the intake gets hot bang there it is again 85iat degrees
up could ping any were 1-3 raps of kr. 02s are at 860 mv, ltft -6 both banks. ive
been running the histrogram seems like very things pretty close,the 2d veiw dont
look so great tho. heat does this pisses me off. eats me alive maby ill desenstizes the knock sensors and try it . evan 93 oct and btlle of 104
still there
still there
you may wanna try to play with the ve in that area. you could have too much spark for the stock ve. you modify one thing, it affects many if im not mistaken, shouldnt your ltft's be 0 when at WOT???
