Wideband tuning on a dyno for sealed "Ram air kits"
I have an 02 Z06 and i am going to be switching to a Vararam. It is a sealed ram air kit that pulls in air through the front fog light openings. Now on a dyno it can only pull in the air that would be coming from the fan infront of it. That's fine and it can be tuned to 12.9 AFR for dyno purposes. Now on the street or track at speed it would be pulling a considerable larger amount of air-so if i set the pe table to read 12.9 across the board won't the added airflow lean out the car? My question is if this is the case then shouldn't the car be tuned to like a 12.5 AFR as a cushion or richer?
Vortech,
I have a Vararam also. I got over 80 dyno runs and hundreds of deserted road runs and have never seen more then .2 to .3 difference in my WB readings. Even then I cannot get the difference to be repeated enough to develop a pattern I would trust, in other words do not worry about it....
Not a current ECU tuning expert, but per the physics and simple electronics, any ram pressure (and with 100% recovery of the velocity head, it's less than 3 kPa @ 150 MPH, ~ 1.25 @ 100) should be read by the MAP sensor as barometric pressure and by the MAF as greater air mass for same volume. Therfore there should be no effect on commanded AFR.
LS1 Tech Administrator
If you actually do get a ram affect, your MAP sensor and MAF will read the increase and adjust accordingly.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
What is the MAF transferfunction? I have a wideband so I guess next time after the car is tuned on the dyno I will have to hit the track and see what happens.
