Codes following Dynotune
I have a bank 2 and bank 1 lean code. Along with two throttle related codes. Should these have been negated by an LS1 edit tune? I need to come up with something, inspection is coming and I'm in NY. Are there any quick fixes or do I need to do more diag to solve the problems?! Thanks for any help.
Could be a mix of stuff. Depends on what they did in the tune. Sometimes they play with the maf frequency,
on they dyno it shows ok, but then, when you are driving home, the ltrims start to relearn and if the ltrims get to far off, it will show those codes. Or i would check your fuel pressure to verify it is correct too. Normally though it is a simple fix.
