Help my 1996 GMC Suburban wont Start
Old 11-30-2005, 04:42 PM
Pro Mouse's Avatar
Angry Help my 1996 GMC Suburban wont Start
Well I am here stuck at work because of this POS!!!Here is the thing The thing just wont start in colder weather.50-60 degree's starts fine but today in 30 degree weather it wont start.Cranks over fine ,I have got spark,The plugs are fairly new Its like it's not even trying to fire!What do you guys think it is.Starts fine in warmer weather but 40 degrees and lower gives me ****.It has been giving me troubles this year since the colder weather,But this time it dont want to start at all.....I hope I have the right forum to post this....Please HELP!!!!
Old 11-30-2005, 05:29 PM
wait4me's Avatar
Fuel pressure is?
Could be moisture in a fuel soloniod and it freezes makeing the fuel pump not kick on?
Old 11-30-2005, 05:39 PM
Pro Mouse's Avatar
I dont have a clue what my fuel pressure is.Where would the soloniod be?I can smell gas thru the exuast pipe.
Old 11-30-2005, 05:53 PM
01WS6/tamu's Avatar
Probably a fuel pump. It may not have enough pressure and it would cause the same problem. When you pull the tank check the pass-thru connector they are bad about burning the terminals in the pass thru.
Old 11-30-2005, 06:06 PM
Pro Mouse's Avatar
But if it is the fuel pump why would it only do it when cold out?I would think it would do it all of the time???
Old 11-30-2005, 07:09 PM
joecar's Avatar
So far you have:
a. 30 degree weather no start.
b. Spark delivered (...did you eyeball this...?).
c. Fuel delivered (smell in exhaust).
d. Fuel smell in exhaust.
Sounds like it may be flooding, possibly due to fuel pressure regulator frozen (or even ruptured, causes flooding also).
What happens if you floor the gas pedal while cranking ("clear flood mode"), does it eventually start and run...?
May be a good idea to check fuel pressure.
Old 11-30-2005, 07:50 PM
SUTTERERMAN85's Avatar
check fuel pressure and if its good unhook a plug wire to make sure you are getting spark ground it to anything metal and get someone to crank it. if no fire it could just be a bad coil and have something to do with the cold.
Old 11-30-2005, 08:16 PM
Pro Mouse's Avatar
Originally Posted by joecar
So far you have:
A=Yes
b=YES
C=YES
d=I dont know
I tried to hold gas pedal down and no Start will not even try to start
Old 11-30-2005, 08:26 PM
Pro Mouse's Avatar
Checked that up against the exaust manifold,Got good spark...Thanks!
Old 11-30-2005, 08:41 PM
SmokingWS6's Avatar
I'd say fuel pump. I owned a 96 yukon, same motor. I'd say the FP is going south, Can you hear the FP kick on you turn on the ingnition.
Old 11-30-2005, 08:43 PM
Pro Mouse's Avatar
No I cant hear it
Old 11-30-2005, 09:07 PM
if you have fuel and spark it will run. you must not have one of these. try pushing the pedal down some while trying to start it. if its flooded it might not run but if you have air which you do, fuel and spark it will run.
Old 11-30-2005, 09:16 PM
wait4me's Avatar
The hei distributer also can control the pulsing of the pump. Maybe the HEi modual is bad? But he has spark. Hmm. ....
Old 11-30-2005, 09:24 PM
Pro Mouse's Avatar
Yes that is correct,I have spark.I thought that was the problem,I was very surprised to see that.Because it is acting like no spark.When I get to work tomorrow I am going to squirt a few drops of gas down the TB to see what happens. I tried to start it with the gas to the floor ,it does nothing just like not touching the pedal.
Old 11-30-2005, 09:27 PM
have you checked the fuel pressure at the fuel rail? that is one of the first things that i would do honeslty
Old 11-30-2005, 09:31 PM
Pro Mouse's Avatar
No all my tools are at home.I had to leave it at work give it a go tomorrow.
Old 12-01-2005, 12:04 PM
SmokingWS6's Avatar
The stock fuel pumps on them are louder than a walbro 255, If you can't hear it at all switching on the ingnition, something is wrong with it.
Old 12-01-2005, 03:47 PM
joecar's Avatar
When you turn the key to on, you should hear the fuel pump run for 2 seconds (and if you have fuel pressure gauge attached you'll see at least 30 psi or so, and it should hold that pressure).
If you don't hear the fuel pump, you can try:
a. connect fuel pressure guage, this will show if fuel pump runs at key on,
b. check fuel pump fuse (under hood, near fuel pump relay),
c. connect fuel pump test wire (under hood, near fuel pump relay) to battery positive and see if fuel pump runs,
d. reseat or replace fuel pump relay.
If neither of these helps, you have to get out multimeter and see why voltage is not getting to fuel pump.
Old 12-01-2005, 09:17 PM
Pro Mouse's Avatar
Well I dont have a fuel pressure gage.I had my families mechanic check it today and yes it;s the dam Fuel pump 400.00 for pump and install is that to much loot?
Old 12-01-2005, 09:43 PM
the pump is like $200 by it self so thats not too bad i guess. its a PITA. i would do it myself though
Quick Reply: Help my 1996 GMC Suburban wont Start
