OS... EFI Live.. Qs...
Well, Ive decided I want tuning software for my 04 Z06, so for the last week Ive been going through EFI vs. HPT posts, and I keep reading how EFI live has an advantage over HPtuners because of the custom OS feature and auto tune feature.. Ive tried searching but have come up with nothing as to what this actually means..
With the custom operating system feature, what exactly can be done?
Also, does HPTuner have an Auto Tune feature?
Does one program have the ability to monitor more PIDs?
As far as mods are concerned, all I have right now is a vararam intake and will probably keep it that way...
BTW, if anyone from HP reads this, a demo program would be really nice to play around with..
Thanks for the help..
custom os i think is 1 2 3 bar. not really positive.
yes hp has auto tune, but not called that. it is just sd tuning. same stuff
i think monitoring pids is the same give or take
no demo. its really not needed.
hp seems the easier of the 2 since its all in lamens terms.
just get what is cheaper and what meets your needs. they will both tune your car, the limiting factor will be you and your ability to use the search button. i have used autotap scanner and didnt really like it. hptuner is my choice. they are very helpful. one even helped me out for a couple of hours on a weekend. a big thanks to him.
Custom OS's are like mentioned above, but with extra small tables that are designed for Live users. Both have the ability to autotune.
They update and add on to the custom OS's frequently. They are in the process now of implimenting some N20 settings.
Both have the tables labeled very close to each other and are very similar in layout, personally I don't see how the termonolgy is an advantage or disadvantage for either. Both require to study and read before attempting to do any tuning.
Autotaps scanner isn't the same as EFI lives. Lives is much more detailed then the autotap version.
* Unlimited free use for any Commercial or Workshop license holder. Other vendors charge $1,000's for unlimited 2-bar program licenses, just about the cost of EFILive alone!
* Retains the standard VE table to make the transition from an existing tune to a custom 2-bar tune simple and fast.
* Valet Mode Speed and RPM limiters.
* Dual Spark map adaptive knock control is fully operational even after MAF sensor has been removed. Includes user control over high/low adaptive spark.
* Fuel mixtures can be based entirely on MAP vs RPM with any AFR commanded at any MAP/RPM point.
* Timing reduction table when in boost.
* Uses standard {SAE.MAP} PID in boost, works with any generic scan tool.
* Supports up to 285kPa of boost, almost 3-bar boost.
- 2bar VE table
- re-enables dual spark map function
- extra boost enrichment table (in addition to regular PE table)
- closed loop disable threshold based on boost (you can trigger when you go into openloop based on boost).
- easy application to your existing PCM operating software.
Cheers,
Chris...
LS1TECH Sponsor
Thanks a lot guys... So the custom OS is more for boosted applications, and bascially with this the pcm monitors additional perimeters, that it normally would not?
Thank you all very much, Im sold on HP.. I loved the interface from the get go but I wasn't sure if I was giving anything up by going with HP.. Seems like you really can't go wrong with either program.. I can't wait to get this thing.. Order being placed today..
Thank you all for answering my questions..
john
john
