fixed some bucking and dipping...
I know a few of us had these issues, I posted on HP Tuners as well. Let me know if it works for anyone else.
Well, I turned off the throttle cracker below 40 mph. Set enable to 40, disable 39. When I push the clutch in the rpms drop dead on 900 and dont move a bit, well a little but nothing that you can see the tach swing back and forth.
This also seemed to help my bucking in 3rd and 4th gear at 1600 rpm.I adjusted the cracker airflow in 1600 for 5th gear speeds and it still has to recover slightly. What I think I might do is zero the table out up to 2200 rpm the whole way and see how that does. That, or I will only let it enable above 50 mph. The car drives much nicer now. Only issue I have, which I think it is related to the o2s hanging on decel, is the rpms will sometimes dip to about 500-600. Only really did it when I was off the gas for a long time and letting it slow by coating in gear. Once I push the clutch in it would dip but recover right to 900 rpm. Seem to be fueling related as it is very rich on those cells on me.
I am going to mess wtih the throttle follower airflow values some more to see what I can do with it. I know there were a few out there needing help with this so I wanted to post up.
Mike
Mike
Originally Posted by P Mack
In my experience, bucking has nothing to do with iac position, so i don't see how throttle cracker could be related to bucking.
ragtop, i adjusted my tables now to allow the cracker airflow, just zeroed out up to 1600 rpm. this seems to have fixed that problem of the rpms comming down too fast on decel. i am sure if i had the fueling right it wouldnt have happend, but my injectors are a little too big for those low map areas right now so i cant really get it any leaner. but then again its possible it might not be fuel related, looked at my log and it went to 0 iac steps, im thinking the car was like "too much air, close iac all the way" well now that i have cracker airflow 2200+ rpm it doesnt make that move to 0 iac steps on decel. i assume its due to the fact that the car slowly comes down from those high rpms now. but once at 1600 it goes down fast but wont undershoot the mark.
Originally Posted by GuitsBoy
Might help up there, but my biggest issue with bucking is slowing down to make a turn and letting the rpms dip down to 1.5K. Thats where it kills me. Im pretty sure I dont take those turns at 40+
Originally Posted by Bill Bowling
I tried changing the cracker table with no help. I did not try to disable below certain MPH/RPM.
Bill
Bill
here is what i have in the car now,
-Enable 10 mph
-Disable 9 mph
-Zeroed cracker out below 10 mph all the way across and from 0-1600 rpm from 0mph down to about 45 mph (cant remember i am in metric)
-leaving the first 4 columns alone in the throttle follower decay in gear, i multiplied the rest of the table by 0.75
-the follower airflow was set to
0.150
0.200
0.250
0.500
0.750
1.000
1.500
2.000
2.500--->2.500
-follower delays were all set to 0
I'd have to look at some logs, but the only time my IAC has ever gone to zero was when I had the TB blade set screw open too much.
FWIW, when I got my IAC table dialed in, my bucking problem pretty much went away. But this was a big change (i.e. the table being adjusted from stock to account for the FAST 90).
yeah my table is dialed in, but i still have issues. drove the car to work this morning and seems fine. i still have some issues but not nearly as bad,esp at low speed or slowing down, those are pretty much fixed. ive got to recheck the ve, idle air, and effecitve aera and make sure they are all alright
