2001 SS throwing codes PO122, PO410
sorry if this is the wrong forum, i appologize. my wifes car recently threw the codes above (PO122, PO410) now i know one of them is the AIR pump and im not worried about that, ill have it deleted out, but the other is the one that worrries me. i looked it up and it says its a Throttle position sensor not reading right. i did have her TB off for a bit with the throttle cables undone, could there be slack in the line causing this code to come up? doughtable i thought, but maybe you guys can give me more info on that. im assuming its not reading the correct voltage, but that is about as far as i can go with that. im not electrical savey. anyone know a way to test/fix this code if you have delt with it before? any suggestions would be appreciated.
Jon
Jon
