which stand alone to run
Old 12-20-2005, 05:59 PM
orange88's Avatar
Question which stand alone to run
ok im going to buy a standalone and wanted to know what you guys think of certian brands.
so let me have it.
buy the way its a turbo motor
Old 12-20-2005, 06:02 PM
V8_DSM_V8again's Avatar
Big stuff 3
Old 12-20-2005, 06:10 PM
KAOS's Avatar
what about that mega squirt stuff. parish is using it and making big power. and from what i hear its affordable
Old 12-20-2005, 06:13 PM
LTLHOMER's Avatar
bs3 hands down
Old 12-20-2005, 06:14 PM
ls1tech.net's Avatar
spamers suck
Old 12-20-2005, 06:30 PM
Whats with that its a
Double
Post
Old 12-20-2005, 07:14 PM
White.Lightning's Avatar
If you wanna get the best go with BS3. Everyone seems to be happy with it. There are a lot of big HP guys running this setup.
Andy
Old 12-20-2005, 07:46 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,089 Likes on 717 Posts
BS3..
I banned the spammer.
Old 12-20-2005, 10:33 PM
disassembled's Avatar
If you have the cash then BS3. If you are on a budget of 1k or less than i would recommend megasquirt.
Greg
Old 12-21-2005, 07:37 AM
orange88's Avatar
Well If I Dont Have The Money Ill Save And Do It Right I Dont Want My Stuff To Blow Up
Old 12-21-2005, 08:40 AM
427's Avatar
BS3 with individual timing and fuel control would be around 1,800.00 shipped. BS3 also makes a entry level ECU that would run bank to bank with ignition control for around 1,000.00 ready to run. Call me at Wheel to Wheel when you are ready and I will help you get the right parts together.
Kurt
Old 12-29-2005, 02:35 PM
dieselgeek's Avatar
As much as an MS freak as I am, that is a heluva deal right there. I will agree that for the money, BS3 seems to be the best choice in commercial standalones these days.
Does the entry level unit control the transmission also?
Old 12-31-2005, 01:25 AM
busta9876's Avatar
Any standalone if not tuned properly could blow your stuff up.
Old 01-09-2006, 09:17 AM
OutlawZ's Avatar
Hey Kurt, do you have a BS3 system that can run an LT1 setup if I still wanted to use the optispark.
And if so what would be the price for the individual timing/fuel control system, and a standalone harness to wire it all up....
The only other question I have is does the system have wideband o2 capability for that 1800 dollar price? And what kind of tuning knowledge do I need to have to set it up initially (like just to get the car to start/idle). I'm a previous user of Gen VI DFI so I have some tuning knowledge but I'd like to know if based on my setup you guys send the boxes out with an initial baseline tune so the car will at least fire. Thanks in advance...
Jason Brisson
tensecLT1@yahoo.com
Old 01-09-2006, 12:27 PM
LS1Tech Co-Founder
There is a BS3 for the LT1 too.
Old 01-09-2006, 12:36 PM
OutlawZ's Avatar
Sweeet... You got any Part #'s.... I found a dealer that works with BS3 local to me but if you have any pn's handy that i might need i'd appreciate it. Thanks John...
Old 01-09-2006, 12:47 PM
LTLHOMER's Avatar
I would just order it from Kurt since they can switch over all the connectors for you to match whatever you might be using. In my case, I had to get the tps, map, and iac stuff swapped from the normal ls1 stuff and getting that done before you get it would be a lot easier and cheaper than what I did. The guy that did mine (not w2w just a local dfi guy) actually wired the map up backwards and I didn't find that out until the 3rd 3-bar map sensor. $225 in map sensors is a little rough.
Old 01-11-2006, 02:58 PM
427's Avatar
No trans control on the entry level box.
Kurt
Old 01-13-2006, 11:15 AM
MPP
MPP's Avatar
We'll be coming out with an EMS for the 99+ LS1 F-bodies soon. It will work with the factory wiring and sensors and requires no wiring - it's Plug and Play so it replaces the factory PCM. It will also have GM Class 2 / SAE J1850 support so the dash will still work correctly unlike other standalones. It will also have full control over the transmission as well as running the engine. You can find more info at AEMPower.com
Old 01-13-2006, 11:35 AM
dieselgeek's Avatar
AWesome!! before MS I had some experience with AEM.
AEM has by far the best online support and user community (as far as COMMERCIAL standalones go, not open-source ones). They set up good forums, aren't afraid of a little online constructive (or destructive) criticism and they work with customers for improvements. For commercial standalones, my opinion is these guys are the best. Frequently, on the MS-EFI boards, we're referred to informative posts on AEMpower forums, and oten they have cross references over to ms-efi. There is a healthy online community there - which I think is overlooked when selecting a standalone.
