Couple of questions (FI)
I am installing a turbo kit at the moment and will be running around 10psi max boost on my stock block with lq9 heads and cam. I dont want to run at 10psi all the time and was thinking of running around 3psi around town and when I felt like it up the boost.
What can I do to run both boost setting on the same tune?
If I turn the boost down or up the tunning will be off.
What can I do???? I need a list of things to buy. I am going to get it tune by a shop if it makes a difference.
If the pcm knows the airflow, just turn the wastegate, and the Timing and Fuel will be compensated for, if you tune the vehicle correctly. As grams/cylinder increase, timing changes cells. As you move more air, the maf signal increases, and fueling is increased.
Ryan
Ryan
Good luck getting any turbo setup properly sized for 10 psi on a V8 to run 3 psi around town.
BUT.. if you insist.. you will have to run small springs in the WG, which I doubt you can get to run 3 psi.
As far as tuning goes... if the car is tuned properly for 10 psi, it would already be turned for WOT at 3 psi as well.
I am not sure what your reasoning is for running around on 3 psi.
I would do a speed density tune because you dont have to worry about your maf maxing out and i think will pick up more power due to better tuning with SD my car all ways stumbled when i got into boost and i took it back to the tuner and he said everything look all right we strap it to the dyno and i lost 100 hp so he reloaded my tune and everything was fine on the way home i had my predator hook up got in to boost an my maf stayed at 0000 and the car stumble again tried it again and i dident cables where fine it was on a 02 camaro check my afr and it went pig rich long story short my maf went bad and it cost me some plugs and ring damage becaus i drove on it for a while befor my motor went with 35000 on it so SD and you will be happy!
