what afr are you running??? pole
Old 12-22-2005, 12:38 PM
SlipMag's Avatar
Default what afr are you running??? pole
curious what air fuel ratio everyone is running and what kinda power and times are you running with it???
Old 12-22-2005, 01:48 PM
LS1Tech Sponsor
hellbents10's Avatar
On N/A vehicles I shoot for 12.6-12.8:1 at torque peak and 12.8-13.1:1 at hp peak and redline. Soem like to be richer then others though. Some liek to be leaner too. This is just a good starting point if you are not on the dyno or at the track to see were you are making more power.
Old 12-22-2005, 07:14 PM
SRPerformance's Avatar
HSV GTS 12.2 afr 405rwhp 12.5 1/4 114mph C4B (callaway) 228/230 cam 11.1 comp
Old 12-22-2005, 07:28 PM
8GTOKLR's Avatar
File Type: txt
Old 12-23-2005, 04:09 AM
ringram's Avatar
With no other changes going from 12.6:1 to 12.5:1 at peak torque netted me 3bhp and ft/lb so I can say that 12.5:1 is best for my speed density mode 2000 LS1 (HSV R8 M6)
Old 12-23-2005, 05:29 AM
LS1Tech Sponsor
Slowhawk's Avatar
About 90% of my H/C cars run 12.5-1 A/F.I've found a 12.5-1 A/F runs faster than 13-1 A/F tuned cars.
Old 12-23-2005, 03:17 PM
SlipMag's Avatar
can anyone send me their maf calibration table if you are running hp tuners.... i am trying to run 13.1 - 1 also if you could send your ve tables..... i am not wanting to toss them at my car i just wanting them to compare to see if i am in line with the route i am going....hahha i need help lol
Old 12-23-2005, 03:26 PM
SSpdDmon's Avatar
12.0 below peak tq
12.2 for peak tq
12.8 for peak hp
12.6 above peak hp
This AFR along with a slight increase to timing (1~3 degrees advance) netted me ~0.2 seconds and ~2mph over the factory tune.
Old 12-23-2005, 05:43 PM
Kleeborp the Moderator™
MeentSS02's Avatar
I run ~12.5 up to peak torque, where it goes down to about 12.44 (@ 4800 RPMs), and then I lean it out to ~13.0 for the rest of the RPM range. My car definitely likes being richer before peak torque...that's for sure. No track times to back it up though...
Even with leaning it out a bit up top, I'm still seeing 83% injector duty cycle with only full exhaust, a little intake, but still stock internals.
Old 12-23-2005, 06:46 PM
ExceSSive's Avatar
Holy crap you are at 83%...I need to scan my car again and see where my IDC is. I did not really pay attention because, I have read in several places that the stock fuel system is good for more RWHP than I am pushing.
Old 12-23-2005, 08:39 PM
MeentSS02's Avatar
I know some guys running cam only that are over 100% duty cycle...I think you can fairly safely run up to almost 100% without too many problems, but it is definitely not recommended, as it just may not be consistent enough.
Old 12-23-2005, 10:46 PM
chrisj6's Avatar
Mine is running at 100%, i have the crappy '99 19# injectors though for the trucks.
Old 12-24-2005, 03:23 PM
SmokingWS6's Avatar
I run 12.6 off the line at low to peak torque, up to 13.1 in the upper range.
Old 12-27-2005, 07:57 AM
SlipMag's Avatar
very nice guys...i think i will try 13.1 and make a second tune for 12.5 i think my injectors maxed out this weekend......will need to upgrade.....any recommendations...?
Old 12-27-2005, 09:00 AM
MeentSS02's Avatar
At least SVO 30#ers. My stock internal '02 with the 28lb injectors is at 83% duty cycle already.
Old 12-27-2005, 10:25 AM
SlipMag's Avatar
kool thanks...
Old 12-27-2005, 11:22 AM
LS1Tech Sponsor
I tuned a cam only 2500hd the other day with stock injectors...over 110% duty cycle!!!!Yikes Would lean out to 13.4:1 up top, time for injectors. It still has manifolds and stock intake.
Old 12-27-2005, 11:26 AM
SlipMag's Avatar
ha....looks like i need some injectors!!!! anyone got any....i know wrong forum...but cant hurt to ask...
Old 12-28-2005, 10:25 AM
SlipMag's Avatar
ttt...
Old 12-28-2005, 11:15 AM
WS6FirebirdTA00's Avatar
i run 12.9-13.2 and make 500 hp with a small cam lol jk but tahts the afr i run and i get my best numbers with it in logging and it feels great. but no hard numbers to back it up on the dyno
