threw SES does this work??
Old 12-29-2005, 08:36 PM
Magnet's Avatar
Default threw SES does this work??
at fbody.com they have these steps to follow and you can reset your SES light does this work...i trust you guys alot more than fbody.com, i dont want to be pullin fuses without any pre-knowledge
heres the link to the page LINK
Old 12-29-2005, 09:01 PM
Magnet's Avatar
someone?? anyone??
Old 12-29-2005, 09:51 PM
black01_WS6's Avatar
hey whats up, I just moved down here. I have done that before and it has worked, but just take it to autozone or something and they will check it for free, and can clear codes. at least then you know what the code is for.
ever go cruzing at the beach.
Old 12-29-2005, 10:07 PM
Magnet's Avatar
i dont go cruising too much....but every once in awhile, i know the code is for my 02's because i i had to run my car with no front or rear 02's just a couple miles homeafter my header install, but anyways i finally got the extensions and simulators today so i put them on but its still shootin the SES and runnin like crap they sound amazing though!!!
Old 12-29-2005, 10:08 PM
Magnet's Avatar
by the way i did the fuse thing and it iddint do anything except make my car search for idol when first cranked... hopefully it will learn it, i think its already getting better
Old 12-29-2005, 10:14 PM
If you have everything set up, like the extensions and sims, then you schould be fine when you get the code removed. It will keep reading the code until you remove it, but you probably already knew that. try taking the negative off the the battery for 15 min or so then put it back on and fire her up. works for some people.
Old 12-29-2005, 10:16 PM
Magnet's Avatar
i think im gonna hit autozone in the morning...i tried tonight but they said they didnt reset codes after dark WTF???
Old 12-30-2005, 07:26 AM
what that is ****. its not that hard to use the scanner.
