Throttle Position is 16 with car NOT started?
can't you just unplug the TPS, turn the ignition on for 5 seconds (but not start the car), and then plug the TPS back in?
This recalibrates the sensor so that whatever the throttle blade is at currently becomes 0% throttle.
Originally Posted by Blown Interceptor
I know its suppose to be at 0. How to I change it?
Thanks!
Thanks!
When I got the new throttle body...the blade was not closed all the way. I though that could be the problem with high idle, but when I took my stock one off, it was the same. The blade was open just a little bit. The guy I bought the TB from said it had new sensors.
Originally Posted by Bink
They are all open a bit - C5 TBs. Your high Idle is due to either a poor porting job or the Idle and Start up airflow tables need to be reduced.
Here is the porting job. Your thoughts?
https://ls1tech.com/forums/generation-iii-external-engine/429302-how-good-port-job-tb.html
I know from gojo and Nick Williams that the rim/lip at the blade-body interface is critical. If this has been removed then no amount of "Tuning" will correct the Idle airflow problems. Hopefully your porter was well versed in C5 TBs.
