p0174 and p0171 = dirty MAF?
is it possible to throw these codes because the oil from a aftermarket filter collects on the MAF, thus sending bad info, thus causing it to run lean?
OK, the answer is yes it will throw codes..you need the clean it with a que tip. The reason no one answered you is because you not running 4000 hp and you are not in anybody clique. People around here really annoy me because this so much knowledge but they just want it for them selves. I would have answer sooner had I seen it. Hope this helps.
https://ls1tech.com/forums/generation-iii-external-engine/432454-dirty-maf-running-lean.html
