How are you guy's plugging the 2nd TB hole after you drilled it out?
Old 01-09-2006, 12:28 PM
SmaknaSS's Avatar
Default How are you guy's plugging the 2nd TB hole after you drilled it out?
I tried to do a search but it has not been working for me lately, I drilled a 2nd hole in my TB blade after a cam install to get my IAC's count's down back in a time when I didn’t know any better to help with my idle issues I was having. My setup has changed since then and now I want to plug up the 2nd hole that I drilled out. What are some of yall’s way’s of plugging up the hole? Does anyone sell throttle blades for a stock TB on a 01 SS. Thanx in advance.
Old 01-09-2006, 12:42 PM
Moderator
jimmyblue's Avatar
I know I've seen somebody selling replacement
blades; think it was one of theTB porting guys.
Pretty cheap as I recall, saw it in one of these
forums.
Old 01-09-2006, 12:56 PM
horist's Avatar
the other option i've heard of people doing is JBWeld over the hole... let it dry, smooth the weld out w/a sander/grinder and then redrill the hole if necessary ... Though if it were my car I'd do as Jimmyblue mentioned...
Old 01-09-2006, 01:20 PM
LS1TECH Sponsor
foff667's Avatar
on my s-10 TB i just used a pop rivet & grinded it down as well as possible...worked without issue for over a year.
Old 01-09-2006, 01:46 PM
GuitsBoy's Avatar
Ive also used a pop rivit in the past with good results
Old 01-09-2006, 02:10 PM
SmaknaSS's Avatar
forums.
That sound promising, thanx everyone for their input.
Old 01-09-2006, 03:58 PM
2xLS1's Avatar
PM Nick Williams. I've seen him offer them pretty cheap.
Old 01-09-2006, 04:47 PM
Nick Williams's Avatar
I probably have a few hundred layin around the shop here. They are all from C5's so they don't have a hole at all. You would just need to drill the correct hole and you will be good to go.
Old 01-10-2006, 09:05 AM
xssive's Avatar
Rivet's work great
Old 01-10-2006, 10:15 AM
WS6snake-eater's Avatar
jbweld here...
