What causes DTC PO751? - LS1TECH
PCM Diagnostics & Tuning HP Tuners | Diablo | Pantera EFI
Thread Tools Search this Thread
Old 06-29-2002, 08:32 PM   #1
Elite_Hot_Rod's Avatar
Default What causes DTC PO751?
About once a week I get an SES light, the code shown on autotap is PO751 1-2 shift solenoid stuck closed. What would be the cause of this? TIA,
P.S, I have a Transgo shift kit installed.
Mark
<small>[ June 30, 2002, 11:38 AM: Message edited by: Elite_Hot_Rod ]</small>
Elite_Hot_Rod is offline   Reply With Quote
Old 06-30-2002, 07:50 PM   #2
Default Re: What causes DTC PO751?
Come on guys surely someone has seen this code before and knows what causes it. Let's hear it...please. Tia,
Mark
Old 07-01-2002, 07:03 AM   #3
gwj
Location: Live Oak, FL - in the woods where the creatures lurk.
What year/ what mods? I think this code comes up on some '01+ cars with a higher stall TC. If the rpm on the 1-2 shift increases between shifts very much it causes the problem. Might try searching the drivetrain forum.
gwj is offline   Reply With Quote
Old 07-01-2002, 03:09 PM   #4
Ragtop 99's Avatar
High stall converters can cause it because of the higher rpm drop. If you have a stock TC, it could be crap in the solenoid or solenoid has gone bad.
Ragtop 99 is offline   Reply With Quote
Old 07-01-2002, 11:26 PM   #5
Thanks Guys,
It's a 99 T/A mods are in the sig. Where is the solenoid located? Please don't tell me it's internal to the transmission, I don't really want to drop the pan. Does anyone have the part number for the 1-2 shift solenoid? Thanks again,
Mark
Old 07-02-2002, 08:22 AM   #6
gwj
Yup, got to drop the pan to replace it.
I'm not saying it HAS to be replaced, but to get to it you have to drop the pan. If you're under the trans while facing the front of the car/trans it's the solenoid on the left rear,at least according to the Helms manual.
Related Topics
Thread Thread Starter Forum Replies Last Post
hp tuners delete question???? blackbullet#1 PCM Diagnostics & Tuning 1 04-01-2012 04:34 PM
Some good side by side Texas drag racing. Elite_Hot_Rod Drag Racing Results 3 09-22-2008 10:20 AM
Code PO751 LS135thSS PCM Diagnostics & Tuning 4 06-06-2006 07:12 PM
Looking for best price or GP on Big Stuff 3. Elite_Hot_Rod Sponsor Sales & Specials 4 04-07-2005 01:29 PM
Cleaning Stripes? Elite_Hot_Rod Appearance & Detailing 5 12-16-2003 10:54 AM
Tags
38, code, codes, diagnostic, dtc, high, located, obd, performance, po751, po751acode, shift, solenoid, stall, stuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
