Does being RICH cause a cloud of smoke when the pedal is hammered
Old 01-14-2006, 05:33 PM
Quickin's Avatar
Default Does being RICH cause a cloud of smoke when the pedal is hammered
I thought my cloud of smoke was white, but today I saw it a few times when I went WOT and it actually looks dark in color. I also get a build-up of pure black soot above each tailpipe on my bumper every 4-5 days. I have to clean it of with Goo-Off or alcohol.
So do you think I'm too rich?
Car runs perfect otherwise.
Old 01-14-2006, 06:34 PM
ninobrn99's Avatar
without looking at your tune, its hard to say, but maybe there's some build up in there. you could try to run a can of seafoam if you a/f is on point or close to it.
Old 01-14-2006, 06:36 PM
Quickin's Avatar
seafoam???? Tell me about it. Can I pick it upand just do it myself?
Is it a cleaner. Because this cloud of smoke only appears at the second I go WOT for maube 1 full secong, than from there on out if I stay on the gas everything is clear. If I go WOT a couple minutes later, same thing happens.
Old 01-14-2006, 06:39 PM
ninobrn99's Avatar
its a liquid. you pour a third of it in your oil fill on the valve cover, 1/3 in the pcv on the driver head and the rest in the fuel tank. its supposed to clean out all the carbon and stuff out the motor and fuel lines. i got mine at napa.
Old 01-14-2006, 06:51 PM
Quickin's Avatar
I'll get some tomorrow.
pcv on the driver head??????? Where's that at?
Old 01-14-2006, 06:54 PM
Quickin's Avatar
Also, when I look at my TB there is a light film of oil (I guess it oil) on the bottom half of the TB plate. If I wipe it with my finger it comes right off, its kind of wet, but it doesn't run down.
What doesw this mean?
I have the valley cover and catch can too.
Old 01-14-2006, 06:56 PM
ninobrn99's Avatar
its on the back of the valve cover. its a black rount thing that goes into the rubber grommet on the valve cover. If it is dirty, then your going to be smoking alot, but that just means that its cleaning. You will also need to do an oil change.
Old 01-14-2006, 07:03 PM
Quickin's Avatar
You mean if TB plate is dirty I'll smoke alot after I pour this stuff in and go driving it?
How long do I drive around? Or do I just idle? Should I go WOT or just drive casual?
Should I do the oil change immediately after driving it around?
Also, is there a problem that needs fixing if the oil is on by TB plate?
Sorry, alot of questions
Old 01-14-2006, 07:11 PM
ninobrn99's Avatar
it has nothing to do with the TB. it will smoke if the internals on the motor are dirty. the oil could be from a k&n filter if your running one. from what ive read, its common to have oil in the intake manifold, but if you have the ls6 pcv system and a catch can, then it shouldnt be doing that. the oil change doesnt have to be the minute your done driving, but within that week i would suggest. just drive it for about 20 minutes to let it run through the system. I think the can tells you how long to also.
Old 01-14-2006, 08:16 PM
2xLS1's Avatar
Your engine needs a rich mixture relative to the 14.7:1 it runs at in closed loop to make power at WOT. Rich mixtures will appear as darker exhaust. Only a wide band A/F sensor will tell you if it is TOO rich. What you are seeing is the extra enrichment the PCM is commanding when it enters PE mode. Quite normal.
Seafoam is just a product people use to clean carbon build up out of the combustion chamber.
Old 01-14-2006, 08:21 PM
ninobrn99's Avatar
who tuned it?
Old 01-14-2006, 08:28 PM
Quickin's Avatar
who tuned it?
Mike Norris, May 2004 when the new engine went in.
I do have a K&N. I'm starting to think its waste of time over paper filters.
Old 01-14-2006, 08:42 PM
ninobrn99's Avatar
that was my problem. it could just be that. its hard to say without looking at you tune.
Old 01-14-2006, 08:48 PM
Quickin's Avatar
Well, I'll run that stuff through it for the heck of it. But I might as well wait to get a new tune after all my new mods get done Like I said, the engine runs as perfect as an engine like this could run. A little smoke when I stomp it doesn't bother me.
Thanks for the input
Old 01-14-2006, 08:52 PM
ninobrn99's Avatar
well good luck with it.
Old 01-14-2006, 09:28 PM
Moderator
jimmyblue's Avatar
Stock tune commands excessive power enrichment.
Cat overtemp protection is even worse. This is all
even without any compounding mixture errors in
play.
The oil on the TB says PCV system, blowby and
oil uptake. Probably want to look into a catch can
scheme of some sort. Otherwise you'll be a regular
SeaFoam junkie.
Old 01-14-2006, 11:09 PM
Quickin's Avatar
play.
SeaFoam junkie.
I have a catch can.
Where would oil come from in front of the TB plate anyway?
Old 01-15-2006, 08:22 AM
Moderator
jimmyblue's Avatar
PCV uptake air line is the left-hand port in the TB.
Idle air is the one more to the center.
The way I see it, at WOT you have near zero
pressure drop across the TB itself, some drop
across the intake tract (filter, lid, MAF) so both
uptake and extract lines of the PCV are under
light suction. Pressurizing the crankcase is any
blowby. So the oil fog whipped up in the rocker
valleys wants to blow on up both hoses, the
uptake one is totally unrestricted however and
probably not catch-canned?
I think someone needs to make an LS1 catch-
can that's small, two chambers (one per hose)
and a nice tuck-up (like bent lines to fit the stock
house routing with little cutting and no extending).
Preferably in black.
Old 01-15-2006, 04:25 PM
Quickin's Avatar
ninobrn99,
All I can say is holy ****
Put the stuff in and went for a 30 minute drive. The engine actually seemed to run a bit better at idle.
Towards the end of the drive I decided to mash the pedal to the floor at 45-50mph and the only smoke I got was from the tires roasting
I don't get hardly any smoke now when I hit it. Could that stuff be that friggin good?
I must have had a shitload of carbon somewhere, eh?
Old 01-15-2006, 04:30 PM
ninobrn99's Avatar
hey, you never know...give it some time though to see how the car runs and if you still experience the same issues. Im glad its worked for you thus far though!
