Questions on Marcin's RAF 1_2
Restricted User
Ok, I converted from a 4L60E to a TH350. I have the NSS hooked up, so the PCM knows when it is in PN, or G. Not sure if it see's like normal or not, as it doesnt seem like I get all the FTC's. Anyway...
When using the RAF sprdsht, does the idle in Gear need to be with Pbrake on? Or could I let it chug forward at idle? I am only experiencing a little dip & surge (d/s) when coming to a stop when warm, and I get a decent amount of d/s when idling from cold start. But, I notice when I am rolling to a stop, or taking off from one, there seems to be a point, maybe based off xxx vs. mph, where it d/s' a lot more than any other time.
So, I got to thinking, maybe I can use the RAF and let off the brake, letting it "idle" creep forward? Probably something not related to the RAF, but more a mph based thing I guess. Any comments or thoughts appreciated.
Charlie
EDIT-I am also trying to figure out to average the column of RAF for each temp. I have sorted by temp and am learning to use Excel as I type! Any hints, pointers etc welcome.
Charlie
Restricted User
Ok, got the average part figured out. Now I know why so many ppl get Laptop mounts in their cars and log all the damn time, the more data gathered, the smoother the tune. I think I need to hold off on any more changes until I swap to a 2002 OS.
Restricted User
Ok, so it would be safe to let it roll, and then anything over 3mph ditch. Got it, thanks Marcin. I have done a RAFP log, actually all the way from cold start (cold start in Hawaii aint saying much). Still building the RAF, I want to gather as much data from different logs as possible. Very cool ss.
Charlie
Charlie
