perfect air/fuel ratio?
Old 08-11-2002, 05:38 PM
Gev
Gev's Avatar
Default perfect air/fuel ratio?
what is teh perfect air/fuel ratio at WOT that i should try to adjust my car to?
mods in sig.
Old 08-11-2002, 06:24 PM
WILWAXU's Avatar
Default Re: perfect air/fuel ratio?
Moving to Computer Diagnostics & Tuning section.
Old 08-11-2002, 06:50 PM
LS1Tech Sponsor
Slowhawk's Avatar
I got my best results with 13-1 across the board.Some like richer and some leaner.
Old 08-12-2002, 01:06 PM
WicketMike's Avatar
what he said,
what ive seen is 12.9-13.1
Old 08-12-2002, 04:13 PM
DenzSS's Avatar
Generally accepted practice for NA is 12.8-13.2
12.8 being a bit rich, 13.2 a bit lean. We ended up tuning mine in at 13.1.
Old 08-12-2002, 04:31 PM
MDL-01C5's Avatar
How much affect on power will running at 11.1-11.8 WOT have?
PontiacMan7901's Avatar
Probably the most desirable AF ratio would be 13.0:1. This would create a stoichiometric atmosphere(not to rich/not too lean)
<img border="0" alt="[angel]" title="" src="graemlins/gr_angel.gif" />
Old 08-12-2002, 07:37 PM
Mr. B's Avatar
How did you all determine your WOT air/fuel ratio?
I have ATAP for the Palm and would like to see what mine is currently at. I definately smells rich.. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old 08-12-2002, 08:03 PM
Moderator
LIL SS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by mrb00formula:
<strong>How did you all determine your WOT air/fuel ratio?
I have ATAP for the Palm and would like to see what mine is currently at. I definately smells rich.. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">.89-.91 on O2 sensors B1S1 B1S2
Old 08-13-2002, 10:15 AM
DenzSS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MDL-01C5:
<strong>How much affect on power will running at 11.1-11.8 WOT have?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You'll find some HP by leaning it out to the 12.8 - 13.2 range. You can't say how much, but on a NA car I'd guess 15HP or more. You'd see a pretty broad change under the curve.
If you're FI, don't go above 12.5. Generally, I'd stick around 12.0 with FI.
Old 08-13-2002, 01:23 PM
1dirtyZ's Avatar
i have a FI set up and it's set at 12.6:1 , the strange thing is i made the most power at 14.1:1 !! <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old 08-13-2002, 02:03 PM
DenzSS's Avatar
LOL
Someimes you'll see a little more power up that high, but your chance of detonating is extremely high. Most of the FI I've worked on has been tuned in at about 12.0.
Old 08-13-2002, 02:10 PM
Reboot's Avatar
You will make more power with a a/f of 13.2 vs. 12.8 but keep in mind the dyno has less load than actual driving so if you target 12.8 you will probably be around 13.0 on the street/track.
Quick Reply: perfect air/fuel ratio?
