What does:" Mass Air Flow (MAF) Sensor Circuit Low Frequency" mean?
My car has been running like crap(super rich), so I decided to pull out the autotap and got the code P0102 which is: Mass Air Flow (MAF) Sensor Circuit Low Frequency
I have a 85 mm SLP MAF sensor which I've used for about 2000 miles. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Anybody have any ideas of what it could be? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Thanks,
Roman
<small>[ August 20, 2002, 03:49 PM: Message edited by: romanss ]</small>
Thanks,
Roman
Re: What does:" Mass Air Flow (MAF) Sensor Circuit Low Frequency" mean?
damn, someone else has this damn code!!!! read this post
https://ls1tech.com/ubb/ultimatebb.p...;f=23;t=002187
Check to see if your "Eng Sense" fuse is blown (under the hood)
if so, replace it
if not try swapping in someone else maf to see if the code goes away.
Chris
if so, replace it
Chris
pretty sure your slp maf is the culprit.return it and get a new one.happen to me with the pace maf 85mm.orcheck it first.put the stock one back check it and put the slp and check.hope you figure it out. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
The last one I fixed with that problem had the harness connector plugged upside down, and therefore some wires crossed.
