Tuning '03 suburban with procharger
just a few questions.
1. truck has 6.0 with stock injectors, should I get lucas 42lb'ers or run stock and check duty cycle and afr
procharger kit is 7-9 lbs
truck has a rising rate FPR, has no KR, but is running lean
have not checked with wideband but narrowbands are only getting to 850
I have an LC-1 and will begin tuning next week
2. Is this the correct path for tuning?
a. injector flow rate(if not using stock injectors)
b. idle tune (if running cam with unstable idle)
c. autotune VE table
d. power enrichment tuning
e. MAF calibration (if still running maf)
3. when does the vehicle enter PE mode?
I looked at the parameters under mixture but it doesnt tell me when PE is operating.
4. should I upgrade to 2 bar map sensor and custom OS to run 7-9 lbs?
would this be easier to tune with?
5. after I reset LTFT's, how much driving is required to see the results?
are reccomended LTFT's different for a boosted vehicle?
TIA for any help
TIA for any help
1. You will definitely need bigger injectors, probably even bigger than 42s. mototron 60s are a popular choice, easy to tune, i've seen them for ~$410 new and ~300 used.
you might wanna get an electronic fuel pressure gauge and log it across the full range, since your FPR is going to make that variable, not static. then you'd have to modify the injectors.xls spreadsheet to accomodate for that (i can do that for you if you'd like).
2.you got it right and in right order!
the only thing i see a problem with is you're gonna max out MAF fairly easy, so you should go with your #4 idea and just go 2 bar SD.
3. log your boost if you can (again, electronic gauges are great for this) and see when your car gets anywhere near boost, and adjust your MAP and TPS accordingly.
5. i usually reset trims, go for a 10-15 min ride where trims go crazy learning, then turn off the engine, go for another 10-15 min ride and that should already have some stabilized results. LTFT's are the same, you just want your PE to be on the rich side, and timing to be really tame (12-16 degs is a good value to start off with)
Originally Posted by J&J Speed Shop
Great info, I was also going to suggest 60 lb. Mototrons because it will give you room to grow.
it's a requirement, not an option.
Is PE mode determined by a certain tps/map reading?
neweraperformanceparts.com has mototron 60#'s for $419 shipped
I will get those ordered
Originally Posted by Gen3Benz
what do you mean adjust map and tps?
under Fuel Control -> Power Enrich, you got 'PE Enable' sectionwith a MAP number. that's one of the triggers.
the other trigger is bit underneath, under 'PE Enable TPS', you got hot and cold tables, both dependent on RPM.
the way to tune these is not that precise, you just need to do some driving and browse the logs, and match up MAP/TPS values for when intake pressure is about to turn into positive. remember that with FI (especially turbos) you can go into positive boost (which is more torque than normal NA setup will see at peak tq) quite early, often under 3000rpm. so adjust these PE enable by TPS(vs RPM) tables accordingly, normally they don't expect any real torque until >4000RPM.
so, 12-16 is the most timing I should see on the WHOLE table or just MAX advance?
so if you got 30* in the non-wot and 16* in WOT area, highlight the 30* row/column, and another three row/columns into the WOT area, and then hit 'interpolate between vertical/horizontal bounds' to get it to be a nice transition. play with this process a little, you'll quickly figure out what i'm trying to get at. have the graph in a little window as you're editing the data so you instantly see what's going on.
there are two triggers that are responsible for going into PE mode (ECT too, but that's a side issue). you will go into PE mode when both TPS and MAP readings are above certain limits.
one problem
I am using efilive software
do you know the parameter to adjust with efilive?
{B3615} and {B3613} seem to be the equivalents. also, there seems to be a bunch more for EFI under Engine->Fuel->Mixture
are there any direct plug-in 60# injectors for the trucks?
I was told that mototron 60's will need different connectors to work.
thanks
no clue about trucks, i'll let others chime in. plenty of FI truck ppl out there, i bet searching for 5 secs will get you the answer.
racetronix.com sells mototron deka 4 60# flow matched shorty's
