Converting ls1edit file to hptuners???
Can anyone do this for me. I have hptuners and I have an ls1edit file that I would like to look at. Is there any way to convert this so i can view it using hptuners? I can send it to anyone who can help!!! Thanks
Moderator
The PCM is the only common ground. If you can get your
cable to it, there you go. But if it's just a found pile of data
you're out of luck (though seems like sooner or later every
encryption gets cracked).
Probably though you're interested in a smaller set of the
tables and the cut-n-paste, Excel way is doable with a
cooperative donor.
cooperative donor.
