POLL - how much timing are you running at wot?
how many degrees of timing are your running at wot and what is your A/f ratio? also list what spark plug and gap you use. since octane varies by state list what octane fuel you are using too. also list your mods like cubic inches, compression ratio and power adders if its not already in your sig.
i am running 25.5 degrees of timing at wot and 12.8:1 A/f ratio. 91 octane gas here. since i plan on adding a dry nitrous kit in the future i am runnin ngk tr6 plugs gapped at .035 > when i spray the juice i will run 100 octane gas
LS1 Tech Administrator
26 degrees at peak torque, 29 degrees at peak hp.
11.0 static compression, 8.20 dynamic compression.
NGK TR6 plugs gapped .045. 93 octane.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by Ls1Joe
36 total with the timimg locked from 4000 up VP Ms103 Stock Ac delco iridum plugs for a Z06. 346ci 10.1 to 1 compression 13.8 to 14.0 air fuel
33 total here with 12.9-13.2 afr
Alot of you guys are running alot of timing.. Curious... have you had it on a chasis dyno and have seen what that timing does for you? just because its not giving you knock counts doesn't mean its the right amount of timing.
I run this on the dyno and the street...
rpm..............timing...........afr
<-3000.........29-30...........14.5
3000-4500.......28.............14
4500-5550.......27.............13.5
5500-6800.......27.............13.3
TR55-plugs, 93 octane, 11.05:1 static, DCR 8.3
LS1TECH Sponsor
timing
I agree with this statement. I have tuned a cam only car " Magic stick" it would make its best power at 31-32 degrees it could take up to 35 degrees but would loose power about 13.5 on the dyno wb and no knock in either tune.
It's interesting, I tried TR55 plugs in my car but they showed signs of being too hot. So I switched to TR6. You guys with more timing, leaner mixtures don't seem to have that problem.
28-29or peak hp.
If I back any of those numbers off i'll lose hp.
As for the folks running 32-36, thats extreme overkill. I've had a few 'old school' guys that dont understand the concept of how ls1 type heads work run up to 36-38* on ls1's. I backed one guys car down from 36 to 28 at the track and he gained quite a few tenths.
