TPS no more than 77%
Old 01-30-2006, 01:17 AM
Michael55123's Avatar
Default TPS no more than 77%
My TPS when the pedal is on the floor is no more than 77%. Is there a way to reset this, or change it?
Old 01-30-2006, 02:23 AM
Restricted User
CAT3's Avatar
Yes, look under the hood, the cable from the pedal to the ASR, or throttle bracket, has a self adjuster on it, and normally when fumbling around under the hood the adjuster clamp comes undone. If you look near the middle of the cable, there will be a "coupler", make sure it is locked down. If you have someone operate the pedal, you should see it flexing if the adjuster is loose.
Charlie
Old 01-30-2006, 04:41 AM
Predator's Avatar
Also, while adjusting the cable, you can hook up a scanner that will tell you, in real time, the percentage your throttle blade is open. I use an AutoXray, but any scanner will work. When it reads 100%, you're done.
Old 01-30-2006, 07:25 AM
Moderator
jimmyblue's Avatar
Snug the cables in the engine bay first, but also check
that you don't have a carpet problem (bunched up)
and last, that you don't have some remaining slack in
the non-adjustable cable from the pedal to the pulley
cluster (TCS cars) that would require you to add a
spacer.
What you're really after is dead horizintal open on the
butterfly (check by ruler) as well as a healthy ~4.6V TPS
voltage (DMM, or read back from PCM).
Old 01-30-2006, 02:01 PM
Yeah I can't get it to open more than 80 percent. I'm thinking maybe my cable from the TB to the little round thingy on the passenger side is broke or stretched?
