LS2 Edit - It's out! Watch out HP Tuner & EFI Live!
Old 02-01-2006, 09:47 AM
Billiumss's Avatar
Exclamation LS2 Edit - It's out! Watch out HP Tuner & EFI Live!
Watch out HP Tuners & EFI Live, you better hurry up or you'll loose market share!
I'm surprised no one has posted this yet. I saw this in the latest issue of GM High Tech Performance.
Old 02-01-2006, 09:54 AM
HumpinSS's Avatar
blah no comparision. No EIO and what do the flash times look like and the ******* interface still looks like ***. I'll Pass
Old 02-01-2006, 09:59 AM
MrDude_1's Avatar
HA!
and tablet PCs?! umm, oook. you try using that in a moving car. lol.
Old 02-01-2006, 10:00 AM
2002_Z28_Six_Speed's Avatar
Hey isn't Brian Reese the Engineering Director at SLP? You would think someone from Carputing, LCC would announce it initally, I guess.
The graphical interface is the same which sucks. You can't import an excel into LS1 Edit. Also, you can't hit the arrow key to move to the next cell in tables while using LS1Edit. You have to type in each number. Can't copy + paste easy. They REALLY should have of redone the interface.
chrisj6's Avatar
lol watch out for what......losing 2% of the market that wanna use another ls1edit product after trying Hptuners or EFIlive? yeah right. Hptuners will have their LS2 support and I dont see them worrying too much over LS2 edit.
Old 02-01-2006, 10:04 AM
Kleeborp the Moderator™
MeentSS02's Avatar
I just sold my HPTuners setup...
Oh no! ****! I don't even have an LS2
Old 02-01-2006, 10:08 AM
Camaroholic's Avatar
Say, that's a good lookin' cable.
Old 02-01-2006, 10:37 AM
Billiumss's Avatar
Just passing info along the way...
I know that HP Tuner & EFI Live don't have to worry too much if any, but I'm very surprised Carputing came out with LS2 Edit first for the masses.
I won't be selling my HP Tuners anytime soon...
Old 02-01-2006, 10:38 AM
MeentSS02's Avatar
I'm sure it probably doesn't have half the features that HPT or EFI does, so I won't be too surprised when it is their last attempt in this market.
Old 02-01-2006, 10:43 AM
slow's Avatar
Touchscreen pc's are the best for tuning, but a tablet, without a keyboard is hard to tune with when you need to type a lot of numbers.
Interface still looks old and outdated.
Ryan
Old 02-01-2006, 10:46 AM
horist's Avatar
I dun seen the new order page for HP Tuners and it's got dat dar LS2 on it too
Good to see Carputing updated the look of their software oh wait....
ruh roh
http://www.hptuners.com/order.php
Down for Upgrades... wonder what that could mean?
Old 02-01-2006, 10:48 AM
SmokingWS6's Avatar
I bet LS2 pcm's are quite expensive. crash!
Old 02-01-2006, 10:50 AM
tici's Avatar
Wrong: you can copy / paste from / to Excel no problems.
I actually scan with Edit and elaborate the data with Excel, then copy the tables in Edit. Really easy.
If you know how to use Excel you can do almost everything with Edit
Old 02-01-2006, 10:54 AM
MrDude_1's Avatar
they wernt first.
ive been reading about LS2 editing on HPtuners forums for a long time.... i havent going into it myself, but only because i dont own a LS2. (and even if i bought a LS2 motor, id run it on the LS1 PCM since im wired for it...)
Old 02-01-2006, 10:59 AM
slow's Avatar
Down for upgrades. Will be back shortly! when I tried to go to hptuners website.
Ryan
FWIW, Carputing started working on it in 2004. It's been available for testing for over a year (as I ordered a large batch of circuit boards this time last year), but I guess this is the first big 'press' that it's seen.
Old 02-01-2006, 07:28 PM
Bullshit. You can't copy tables easily from Excel into LS1Edit. You can't use LS1Edit like Excel. LS1Edit has a tough-to-use interface. You have to manually click on each square and edit it. You can't paste many cells into a table in LS1Edit at the same time. I have LS1Edit and use it often.
Also, I find it funny that LS2Edit is still using serial communications to go from the interface to the laptop. I don't have a problem with RS232 since the car is using serial communications anyways, but many newer laptops don't come with a RS232 port. They have USB only.
Old 02-01-2006, 07:47 PM
horist's Avatar
The cable that is pictured is a USB cable... it's a serial looking cable from the OBDII port to the Cable, then USB out of the cable...
Old 02-01-2006, 08:59 PM
aww I see the end of an USB cable neatly tucked into the bundled wire now.
Old 02-02-2006, 12:58 AM
tici's Avatar
Hey, it works here...
I prefer to copy the whole table also if I changed only few values.
"Copy" in Excel, "select all" in Edit, "paste" in Edit.
Works also the opposite way.
Quick Reply: LS2 Edit - It's out! Watch out HP Tuner & EFI Live!
