Anyone throw this 801 code??? Reverse Inhibitor
Saw it along time ago ended up being the solenoid. Here is a flowchart to get you pointed in the right direction.
http://www.ls2.com/boggs/dtcs/DTC%20P0801.htm
HTH
HTH
Thanks a lot man. Sorry took so long to respond but I was at training for awhile away from a computer. So you think its just the solenoid?? Where is it located? Thats about all I'd need to know I think.
thanks again man.
thanks again man.
LS1TECH Sponsor
I could be totally wrong but I m guessing if you have this done you just did an m6 to auto swap. The Reverse inhibitor is reverse lockout I think. I would just delete the dtc out if I were you it does not effect anything but will keep the light on. If Im wrong sorry but I believe Im correct.
thanks again man.
thanks again man.
