OMG! Just set SES light and pulled all the current, pending &Immature codes!
Old 11-13-2002, 01:13 PM
Blackbird's Avatar
Default Re: OMG! Just set SES light and pulled all the current, pending &Immature codes!
thats almost every f'n code there is.
I think you have a fried pcm or something of that nature.
does the car even run?
Old 11-13-2002, 01:27 PM
Restricted User
EFILive's Avatar
Only codes marked with C=Current, H=History and or P=Pending should be considered as "real" codes.
ALL the others can be ignored - especially "I" and "O" codes.
The I codes = Immature which means the PCM has seen a condition that *MAY* be in some way related to that code. But it CANNOT and should not be considered as a "real" code because not enough other conditions were/have been met.
The O codes = Old and are codes that have been previously set but are not currently set (unless accompanied by H,C or P).
You only have one code to concern yourself with:
P0440 Engine controller ($10) M P O H 1 - C I Evaporative Emission Control System
It also has a history freeze frame which you can se eby clicking on the History button.
Most vehicles have just as *many* of these types (I and O) codes as yours, you should not be concerned about them - just ignore them.
You can switch off the display of Old and Immature codes in the Advanced Tab page of the properties window. There is really no need to "see" these codes except maybe for your own interest.
The ability to display these Old and Immature codes was added after a number of customers requested the feature.
Regards
Paul
Old 11-13-2002, 01:37 PM
2K1SS's Avatar
When i spoke with my service advisor he said it was probaly a loose gas cap.
Should I reset all the codes? I have used the history feature it is interesting to say the least. I also used it at a dealership durring a test drive for a freind. The salesman almost fliped out! It was a nice to know more about the car than he did!! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Thanks!
Old 11-13-2002, 03:40 PM
gwj
gwj's Avatar
Location: Live Oak, FL - in the woods where the creatures lurk.
Wow! Sounds like a record to me. Have you pulled the connectors off your pcm and cleaned everything up? Sounds like you are getting some shorts, somewhere.
"Loose gas cap" his ***.
Good Luck.
BTW, if you decide to pull the pcm connectors, unhook one of your battery cables first. Then check for corrosion or "blackend" terminals.
<small>[ November 13, 2002, 03:42 PM: Message edited by: gwj ]</small>
Old 11-13-2002, 04:48 PM
Blackbird's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Only codes marked with C=Current, H=History and or P=Pending should be considered as "real" codes.
ALL the others can be ignored - especially "I" and "O" codes.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Learn something new every day <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I have never seen it displayed that way so I figured it was setting all of them at once.
Good to know.
Old 11-13-2002, 06:02 PM
2K1SS's Avatar
LOL,
All the SES light was from is the gas cap was loose! <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
It's gone now and back to trying to dial in my Ltrims.
Old 11-14-2002, 12:06 AM
2K1SS's Avatar
Default OMG! Just set SES light and pulled all the current, pending &Immature codes!
Does anyone see some thing I need to take a look at? The dealer said not to clear them and he will check them all out.
If I could get some feedback I could stress some issues if needed.
DTC Mudule MIL Pending Old History Mfg1 Mfg2 Current Immature Description
P0440 Engine controller ($10) - - - - - - C - Evaporative Emission Control System
P0440 Engine controller ($10) - P - - - - - - Evaporative Emission Control System
P0101 Engine controller ($10) - - - - - - - I Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Engine controller ($10) - - - - - - - I Mass or Volume Air Flow Circuit Low Input
P0103 Engine controller ($10) - - - - - - - I Mass or Volume Air Flow Circuit High Input
P0106 Engine controller ($10) - - - - - - - I Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Engine controller ($10) - - - - - - - I Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Engine controller ($10) - - - - - - - I Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0112 Engine controller ($10) - - - - - - - I Intake Air Temperature Circuit Low Input
P0113 Engine controller ($10) - - - - - - - I Intake Air Temperature Circuit High Input
P0117 Engine controller ($10) - - - - - - - I Engine Coolant Temperature Circuit Low Input
P0118 Engine controller ($10) - - - - - - - I Engine Coolant Temperature Circuit High Input
P0121 Engine controller ($10) - - - - - - - I Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem
P0122 Engine controller ($10) - - - - - - - I Throttle/Pedal Position Sensor/Switch A Circuit Low Input
P0123 Engine controller ($10) - - - - - - - I Throttle/Pedal Position Sensor/Switch A Circuit High Input
P0125 Engine controller ($10) - - - - - - - I Insufficient Coolant Temperature for Closed Loop Fuel Control
P0128 Engine controller ($10) - - - - - - - I Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
P0131 Engine controller ($10) - - - - - - - I O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132 Engine controller ($10) - - - - - - - I O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133 Engine controller ($10) - - - - - - - I O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 Engine controller ($10) - - - - - - - I O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 Engine controller ($10) - - - - - - - I O2 Sensor Heater Circuit (Bank 1 Sensor 1)
P0137 Engine controller ($10) - - - - - - - I O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138 Engine controller ($10) - - - - - - - I O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0140 Engine controller ($10) - - - - - - - I O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 Engine controller ($10) - - O - - - - I O2 Sensor Heater Circuit (Bank 1 Sensor 2)
P0151 Engine controller ($10) - - - - - - - I O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152 Engine controller ($10) - - - - - - - I O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 Engine controller ($10) - - - - - - - I O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 Engine controller ($10) - - - - - - - I O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 Engine controller ($10) - - - - - - - I O2 Sensor Heater Circuit (Bank 2 Sensor 1)
P0157 Engine controller ($10) - - - - - - - I O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 Engine controller ($10) - - - - - - - I O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0160 Engine controller ($10) - - - - - - - I O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 Engine controller ($10) - - O - - - - I O2 Sensor Heater Circuit (Bank 2 Sensor 2)
P0171 Engine controller ($10) - - O - - - - I System too Lean (Bank 1)
P0172 Engine controller ($10) - - O - - - - I System too Rich (Bank 1)
P0174 Engine controller ($10) - - O - - - - I System too Lean (Bank 2)
P0175 Engine controller ($10) - - O - - - - I System too Rich (Bank 2)
P0200 Engine controller ($10) - - - - - - - I Injector Circuit
P0230 Engine controller ($10) - - - - - - - I Fuel Pump Primary Circuit
P0300 Engine controller ($10) - - - - - - - I Random/Multiple Cylinder Misfire Detected
P0325 Engine controller ($10) - - - - - - - I Knock Sensor 1 Circuit (Bank 1 or Single Sensor
P0327 Engine controller ($10) - - - - - - - I Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0332 Engine controller ($10) - - - - - - - I Knock Sensor 2 Circuit Low Input (Bank 2)
P0335 Engine controller ($10) - - - - - - - I Crankshaft Position Sensor A Circuit
P0336 Engine controller ($10) - - - - - - - I Crankshaft Position Sensor A Circuit Range/Performance
P0341 Engine controller ($10) - - - - - - - I Camshaft Position Sensor A Circuit Range/Performance (Bank 1 or Single Sensor)
P0342 Engine controller ($10) - - - - - - - I Camshaft Position Sensor A Circuit Low Input (Bank 1 or Single Sensor)
P0343 Engine controller ($10) - - - - - - - I Camshaft Position Sensor A Circuit High Input (Bank 1 or Single Sensor)
P0351 Engine controller ($10) - - - - - - - I Ignition Coil A Primary/Secondary Circuit
P0352 Engine controller ($10) - - - - - - - I Ignition Coil B Primary/Secondary Circuit
P0353 Engine controller ($10) - - - - - - - I Ignition Coil C Primary/Secondary Circuit
P0354 Engine controller ($10) - - - - - - - I Ignition Coil D Primary/Secondary Circuit
P0355 Engine controller ($10) - - - - - - - I Ignition Coil E Primary/Secondary Circuit
P0356 Engine controller ($10) - - - - - - - I Ignition Coil F Primary/Secondary Circuit
P0357 Engine controller ($10) - - - - - - - I Ignition Coil G Primary/Secondary Circuit
P0358 Engine controller ($10) - - - - - - - I Ignition Coil H Primary/Secondary Circuit
P0410 Engine controller ($10) - - O - - - - I Secondary Air Injection System
P0412 Engine controller ($10) - - - - - - - I Secondary Air Injection System Switching Valve A Circuit
P0418 Engine controller ($10) - - - - - - - I Secondary Air Injection System Relay A Circuit
P0420 Engine controller ($10) - - O - - - - I Catalyst System Efficiency Below Threshold (Bank 1)
P0430 Engine controller ($10) - - O - - - - I Catalyst System Efficiency Below Threshold (Bank 2)
P0442 Engine controller ($10) - - O - - - - I Evaporative Emission Control System Leak Detected (small leak)
P0443 Engine controller ($10) - - - - - - - I Evaporative Emission Control System Purge Control Valve Circuit
P0446 Engine controller ($10) - - O - - - - I Evaporative Emission Control System Vent Control Circuit
P0449 Engine controller ($10) - - - - - - - I Evaporative Emission Control System Vent Valve/Solenoid Circuit
P0452 Engine controller ($10) - - - - - - - I Evaporative Emission Control System Pressure Sensor Low Input
P0453 Engine controller ($10) - - - - - - - I Evaporative Emission Control System Pressure Sensor High Input
P0461 Engine controller ($10) - - - - - - - I Fuel Level Sensor Circuit Range/Performance
P0462 Engine controller ($10) - - - - - - - I Fuel Level Sensor Circuit Low Input
P0463 Engine controller ($10) - - - - - - - I Fuel Level Sensor Circuit High Input
P0480 Engine controller ($10) - - - - - - - I Cooling Fan 1 Control Circuit
P0481 Engine controller ($10) - - - - - - - I Cooling Fan 2 Control Circuit
P0500 Engine controller ($10) - - O - - - - I Vehicle Speed Sensor
P0506 Engine controller ($10) - - - - - - - I Idle Control System RPM Lower Than Expected
P0507 Engine controller ($10) - - - - - - - I Idle Control System RPM Higher Than Expected
P0530 Engine controller ($10) - - - - - - - I A/C Refrigerant Pressure Sensor Circuit
P0562 Engine controller ($10) - - - - - - - I System Voltage Low
P0563 Engine controller ($10) - - - - - - - I System Voltage High
P0601 Engine controller ($10) - - - - - - - I Internal Control Module Memory Check Sum Error
P0602 Engine controller ($10) - - - - - - - I Control Module Programming Error
P0604 Engine controller ($10) - - - - - - - I Internal Control Module Random Access Memory (RAM) Error
P0608 Engine controller ($10) - - - - - - - I Control Module VSS Output A
P0645 Engine controller ($10) - - - - - - - I A/C Clutch Relay Control Circuit
P0650 Engine controller ($10) - - - - - - - I Malfunction Indicator Lamp (MIL) Control Circuit
P0704 Engine controller ($10) - - - - - - - I Clutch Switch Input Circuit Malfunction
P0801 Engine controller ($10) - - - - - - - I Reverse Inhibit Control Circuit
P0803 Engine controller ($10) - - - - - - - I 1-4 Upshift (Skip Shift) Solenoid Control Circuit
P1111 Engine controller ($10) - - - - - - - I IAC Sensor Intermittent High Voltage
P1112 Engine controller ($10) - - - - - - - I IAC Sensor Intermittent Low Voltage
P1114 Engine controller ($10) - - - - - - - I ECT Sensor Intermittent High Voltage
P1115 Engine controller ($10) - - - - - - - I ECT Sensor Intermittent Low Voltage
P1121 Engine controller ($10) - - - - - - - I TP Sensor Intermittent High Voltage
P1122 Engine controller ($10) - - - - - - - I TP Sensor Intermittent Low Voltage
P1133 Engine controller ($10) - - - - - - - I HO2S Insuffucient Switching Bank 1 Sensor 1
P1134 Engine controller ($10) - - - - - - - I HO2S Transition Time Ratio Bank 1 Sensor 1
P1153 Engine controller ($10) - - - - - - - I HO2S Insuffucient Switching Bank 2 Sensor 1
P1154 Engine controller ($10) - - - - - - - I HO2S Transition Time Ratio Bank 3 Sensor 1
P1258 Engine controller ($10) - - - - - - - I Engine Coolant Over Temp Fuel Disable
P1336 Engine controller ($10) - - - - - - - I CKP System Variation not learned
P1380 Engine controller ($10) - - - - - - - I ABS DTC Detected, Rough Road
P1381 Engine controller ($10) - - - - - - - I Misfire Detected, No EBTCM/PCM
P1415 Engine controller ($10) - - O - - - - I Air system Bank 1
P1416 Engine controller ($10) - - O - - - - I Air system Bank 2
P1441 Engine controller ($10) - - O - - - - I EVAP System Flow, Nonpurge
P1539 Engine controller ($10) - - O - - 2 - I A/C Clutch Status Circuit High Voltage
P1546 Engine controller ($10) - - O - - 2 - I A/C Clutch Status Circuit Low Voltage
P1626 Engine controller ($10) - - - - - - - I Theft Deterrent System Fuel Enable Circuit
P1635 Engine controller ($10) - - - - - - - I 5 Volt Reference #1 Circuit
P1637 Engine controller ($10) - - - - - - - I Generator L Terminal Circuit
P1639 Engine controller ($10) - - - - - - - I 5 Volt Reference #2 Circuit
P1683 Engine controller ($10) - - - - - - - I Unknown trouble code: 1683
Quick Reply: OMG! Just set SES light and pulled all the current, pending &Immature codes!
