Idle Tuning???
Idle Tuning???
Got my 408 fired and idles,just wondering when idle tuning does the TP% need to be at 0% at rest,I have my TP sensor volts at .65 volts at rest but TP% is at 4%.I am having idle hunting problems.Its my fresh 408,afr 205s,TXGiant,fast 90/90.
I don't know about unhooking it while running, how I do it, is just unplug it with the car off, then turn the ignition key to "on" without turning the engine on, and let it sit for a couple mins. Then, turn it back off, plug it back in, and then it should be reset to 0%. Then clear the DTC that you'll throw from having it unplugged...no engine running needed.
Good luck!
Adrian
Good luck!
Adrian
I tryed this on a friend's 395 ci stroker with the Fast 90/ TPIS 90 TB and it wouldn't reset to zero, but since it is ETC I assumed it needed to be cracked since there is no TB hole..
Anyone know for certain?
