Blipping the throttle
Looking to make the engine revs come down a little sooner when blipping the throttle a little in neutral. Nothing extreme, just seems these engines are slow at returning back to idle compared to an sbc or late model Mustang. I've fixed the hanging idle/cruise effect in the past using hptuners, so that's not the issue. What do I adjust? Throttle cracker, follower, decay, delay? Thanks for any info.
I made the changes to the Throttle Cracker Airflow table like you guys suggested and it made a nice difference how fast the throttle returns to idle. Not quite SBC style yet, but real close. I actually copied your table WS6FirebirdTA00 from this thread
https://ls1tech.com/forums/showthrea...ight=weirdness and will be tweaking it.
Thanks for the info guys!
Cracker holds the throttle open a little while moving, perhaps to smooth gear shifts etc. So mess with that to sort out idle speeds while moving.
Follower is there to help smooth ramp in and out of the throttle under all conditions so mess with follower decay for when stationary. (And moving) There is an "in gear" and "P/N" table for both situations.
Both cracker and follower can be active at the same time and get summed together.
If you want to try something for fun, try ramping up the follower airflow values, you will get a much better response to the throttle to match your now fast counter drop in rpm.
Hey WS6FirebirdTA00,
The changes you sent me worked very well. The idle comes down nice and quick and the idle even sounds meaner for some reason. I need to tweak it just a tad because it wants to go below my set idle speed just a little for just about a second but other than that, it was a nice change. Now I'll be looking at some more changes to the airflow values like ringram is talking about. I'd like a little bit crisper/faster throttle response going up in rpm.
