how to tune using LS1edit?
tunning my 2000 LS1 camaro using LS1edit
any one have an article on how to tune my LS1 camaro using LS1edit? i just want to know the basics. i will use wide band O2 for tuning.
i found a very usefule article on how to tune using LT1edit but i didn't find for LS1edit, any one?
is LS1edit tuning exactly the same as LT1edit tuning?
i want to know how to tune in closed loop for MAF tables and VE, timing table and such and open loop for Power Enrichment (PE) table and any thing else for i might need to learn. thanks for help.
https://ls1tech.com/forums/pcm-diagnostics-tuning/304025-guide-ve-tuning-using-fuel-trims.html
This should help you get started. You will need scanning software to use with LS1 Edit. The document was written for use with HP Tuners, but it is a good document.
