so I've been idle tuning with an lc1 wideband
Old 02-22-2006, 09:52 PM
soslo's Avatar
Default so I've been idle tuning with an lc1 wideband
And I've got the A/F dialed in at startup/idle...for about 10 seconds, then the car slowly climbs from high 14s to 18:1.
I'm using LS1Edit btw.
Is there another place besides the VE table that the car takes its idle A/F values from? I've read that the MAF takes over once the electronics heat up - but what LS1edit table controls the MAF idle then? Or is it some other table?
I've found for my car that scaling the 400-1200 VE cols by 90, then by 93 again, gives me a 15:1 idle A/F...now I just want that value to stay there
Old 02-24-2006, 10:29 AM
Bad30th's Avatar
Do you have the AIR pump still running at startup ? That will throw your readings way off to the lean side since it's pumping air into the exhaust.
Rob (Bad30th)
