blowing fuses (car runs like poo)
well my car started running like poo the other day with random misfires. So i checked the codes and it said "MAF sensor low freguency" and reverse lock out selinoid and skip shift selinoid are inactive. Last time this happened i had a 02 sensor wire touch a header and burn, then when the exposed wire got wet it blew my engine sensor fuse. Well last night i got under the car and saw that it had happened again, so i replaced the 02 tied it up out of the way replaced the fuse, reset the comp then started it and for about 5 minutes of driving everything was fine then it started again. any ideas guys??
i need to fix this now. i was out last night and saaw a whole bunch of people that needed a whoopin but i couldnt do anything since i was in a slow *** C5.
