im expecting EFILIVE within the next couple fo days...what wideband?
hey guys i am expecting EFI live within the next couple of days and i want a wideband o2 to go with it as well. i see a lot of people mention the LC-1. but which one do i buy? i see them with guages without guages...etc. can someone steer me in the right direction please.
Thanks
Louie
Thanks
Louie
Hi Louie,
I personally run the LC1 and XD1 together in my owb car, and have been very pleased. It makes for a clean install. I run it in place of the single NBO2 in my OBD1 setup, and use the simulated NB signal to keep the factory ECM happy. I do wish it had some memory and instant playback, but I can get that from the datalogs.
Hope this helps,
-Craig
Hope this helps,
-Craig
ok, so i am just going to buy an LC-1 and then wire it directly into my flashscan, later down the road when i am boosted, i may choose to get a second one and from there have that one mount inside with a reading. is this a good idea?
Thanks
Louie
Thanks
Louie
if you want a wideband for just your car get the LC-1 and install a digital gauge, I wouldn't recommend an analog gauge, that way the digital gauge gives you the exact readout.
if you want to put the wideband on other cars, i would suggest the LM-1
