New Tuning solution?
Anyone know anything about Jet's new software?
So now there is:
EFIlive
TunerCAT
Carputing
HP Tuners
JET
and I've even heard Crane Cams has software coming, the tuning world is getting interesting.
Designed for hardcore racing enthusiasts and professional tuners, the JET Dynamic Spectrum Tuner is a powerful tuning package. JET’s DST software provides you with the tools needed for precise performance tuning using your laptop or PC. Use of this software will give you the ability to modify virtually every aspect of the vehicle’s programming.
Stock programming from the vehicle is initially downloaded and saved to your PC using the supplied JET interface cable that connects to the vehicle’s diagnostic port. The stock programming can be reloaded to the computer at any time to return the vehicle’s ECU to its original state.
The comprehensive, easy to use software allows extensive modification to the vehicle’s software. This allows control of fuel and spark tables, speed and rev limiters, transmission functions, torque management tables and many other functions, Modifications are made using detailed table and graph views for easy and accurate parameter editing. Your modifications are saved as a new file and downloaded to the vehicle’s computer.
DST™ Programming Options Include:
•Fuel parameters including power enrichment and volumetric efficiency
•Ignition tables including spark advance vs load, knock retard and more
•Transmission shift points, shift pressures, and TCC apply and release
•Diagnostic tables including fuel and air, ignition and emissions controls
•Speed calibration tables to correct speedometer and shift points
•Idle controls, fan temperature settings and torque management tables
•Disable factory diagnostic trouble codes
•To see all of the available features please try our full demo version!
DOWNLOAD THE FREE DEMO VERSION FROM THE NEW PRODUCTS SECTION ON THE HOMEPAGE. http://www.jetchip.com/newproduct.asp
The JET Dynamic Spectrum Tuner will be available in March 06.
Capability: All GM OB2 pcm's,
96-06 GM truck or SUV
96-97 LT1 cars
97-05 LS1 cars
So now there is:
EFIlive
TunerCAT
Carputing
HP Tuners
JET
96-97 LT1 cars
97-05 LS1 cars
I just downloaded it, to see what it looks like, It probably has no where near the capability of EFI, or the other big ones. But looks like it will be another tuning solution for LT1's and GM trucks and SUV's.
LS1TECH Sponsor
Originally Posted by 99FormulaWs6
Cool another tuning solution, to market, anyone know about the Crane cams software?
What I like is the 96-06 truck tuning, and the LT1 tuning, if it's affordable, this is a good thing, I agree TAquickness, while it's just shinier, it's still another option.
