Is there an easy way to change injectors
Is there a way to go into HPtuners and change from the factory 28.8 pounders to SVO 42 pounders or do you have to retune the entire car.
If there is a way could you tell me step by step how to do it. Im tuning retarded sorry. Also this is on a 98 . Thanks for any help.
Moderator
It's pretty straightforward, one table change,
unless your new injectors then expose other
fuel delivery nonidealities (like a weak pump
or witing, etc.). Pull down one of the injector
spreadsheets, enter old & new values, copy &
paste into the tune, badda-bing. Did this last
week and the injectors (42# Delphi) changed
trims insignificantly across the swap event.
If you have already been messing the IFR data
around to compensate other, non-fuel-delivery
things though it might get more involved.
Could you please send me a copy of your bine file with the new values for me to compare mine to.
gtformula@yahoo.com Please help.
