HP Tuners VCM Suite Demos
LS1TECH Sponsor
Demos:
You can view online demo's of common VCM Suite tasks:
VCM Editor
Reading your VCM
Writing Calibration to the VCM
Failed VCM Calibration Write - VCM Recovery
Changin Fan Settings - 160 Degree Thermostat
Applying a 1 Bar SD Enhancement
Applying a 2 Bar SD Enhancement
Using the Compare Feature
VCM Scanner
Adding and Removing PIDs
Creating a Custom PID and Adding a Custom PID to the Histogram
Creating a user defined EIO Input
Using Plot Filtering in Histograms
If you guys have any other demo requests, please feel free to ask. Thanks!
- Keith, HP Tuners
VCM Editor
Reading your VCM
VCM Scanner
- Keith, HP Tuners
LS1TECH Sponsor
im sure there are certain things they really cant show you hand in hand because of epa restrictions. As far as timing goes the larger the # the more timing...the lower the number the less timing...for pe fueling the larger the number the more fuel the lower the number the less.
Great job, looks like a lot of hard work went into it.
Just tried to add/remove PIDs, & can't. After I highlight one, then right click, non of the selections in the drop down box can be selected. Please advise.
-Tucker
-Tucker
-Tucker
-Tucker
its just a double click to add stuff from th edrop down menu..
if you have already maxed out your table(like when the vehicle only supports 24PID bytes and you have 24 already in there) then you have to remove one before you can add another
Nevermind, I had a log file open while I was trying to change the PIDs. Closed the file & can add/remove now. Thanks [/HIJACK]
